V2 Station Information
Re: V2 Station Information
Since I dont need LOG4OM V2 to look up a membership number for me (it is something I lookup externally and enter into the logging program myself anyway), a workaround i found is this: i will just input the respective club # in the "Comment" section because then it does shows up in the columns displayed when I choose the "Recent QSOs (F7)" tab. From there I can also detach the QSO's for review or copy them into a spreadsheet for further analysis.
Rob,
Good evening. BTW - check your gmail account as I sent you a message from my e-mail at 05:48 this AM.
Anyway, below are a couple links for some of the data you might be looking for. You might be able to download files as well.
SKCC Membership Roster: https://www.skccgroup.com/membership_da ... roster.php
SKCC Member Lookup: https://www.skccgroup.com/membership_da ... r_info.php
OMISS Roster Information: http://www.omiss.net/Facelift/rosters.php
Under current V2 configuration I put the SKCC name and number in the drop-down area at the F5 Tab. I also put the OMs SKCC # in the Notes field.
You've noted a good plan to work around certain elements that we have not yet turned on in V2.
Thanks much for you questions and observations.
If you're interested in downloading the SKCC membership database, you can find it here:
https://www.skccgroup.com/search/skcclist.txt
How can I create a filter to search the value selected for "Contact Clubs & Assoc's" (chosen in the "Extended info F5" when logging the QSO)?
In "Standard Fields" in the filter dialog I see a ContactAssociations but that doesn't seem to be it. (What is it?
I can not find in the user manual Log4OM's schema so can't use the custom query.
Log4OM version 2.10.0.0
Manual: Updated: 18/12/2020 7:17 PM
Mike
Mike
This facility of viewing and filtering has yet to be addedKA4CDN wrote: 08 Jan 2021, 12:01 How can I create a filter to search the value selected for "Contact Clubs & Assoc's" (chosen in the "Extended info F5" when logging the QSO)?
Mike
Thank you Terry.
Has any thought been given to providing a technical document to the database schema so that users can construct custom queries?
