Some Minor Requests
NS2R
Some Minor Requests
Post by NS2R »
Is it possible to display the total amount of QSO's in log regardless of what the view limit is set to? It was that way in V1. The total count was on the bottom left. Also is it possible to shrink the detached log window to about 1 inch wide and 2 inches high? I was able to do that in V1. Thanks for any possible help..Phil
Re: Some Minor Requests
Phil,
I can shrink to about 1-inch high and 2-inches wide ... give or take. Opposite of what you are asking it appears.
Have you looked at the lower left of your V2 Main UI? QSO count should be visible there.
NS2R
Post by NS2R »
Hi Nolan, I had the bottom cut off because the main window was positioned too low; my mistake. I can see the total count now. I still can't get the detach window less than 8" wide and 3" high. Maybe the next update will have the ability to get it smaller. I was able to get it down to 1" by 2" in V1. Thanks...Phil
