always no tx fldigi & log4om
F1SMV
Re: always no tx fldigi & log4om
Post by F1SMV »
GE Bojan and the group
Bojan i put same same cfg than yous screen copy , but always nothing :(
SQ5TDZ, i think this new version must be update..i will continue use wsjt with dx labs in waiting next version. After more one week its'enough hi...
Ik0Tix , no ..with old version i dont split any port all run very well may its possible to use this part in new version i dont know i am not coder
thank all for your help
73 Eric
IK0TIX
Post by IK0TIX »
I confirm, in my case also, that TCP/IP only allows me to synchronize the frequency but does not send the rig in TX.
I tried the settings for Bojan: no TX
Max IK0TIX
IK0TIX wrote: 31 Jan 2020, 13:09 I confirm, in my case also, that TCP/IP only allows me to synchronize the frequency but does not send the rig in TX.
Please read my reply in this thread https://forum.log4om.com/viewtopic.php? ... =10#p25352 radio is controlled from FLDigi not from Log4OM
IK0TIX
Post by IK0TIX »
so the problems are due to fldigi?
we have to wait for a new release
Max IK0TIX
HB9VQQ
Post by HB9VQQ »
There is no problem currently. I have all working fine with FLdigi and Log4OM.
Flex 6600 - Spiderbeam
SQ5TDZ
Post by SQ5TDZ »
but for everything to work well you need to use vspe software ?
Andrew.....SQ5TDZ
HB9VQQ
Post by HB9VQQ »
You need a virtual serial port emulator.
SQ5TDZ
Post by SQ5TDZ »
ok thanks, too bad it doesn't work without vspe
Regards
Andrew.....SQ5TDZ
HB9VQQ
Post by HB9VQQ »
If two Programs want to talk to the same physical USB Port you always need some sort of virtual serial port.
SQ5TDZ
Post by SQ5TDZ »
in the older version log4om v1 and fldigi, worked without vspe
Andrew.....SQ5TDZ
