So what is different about my setup? 90% of mine are incorrect.HB9VQQ wrote: 02 Feb 2020, 15:41 I went through my last 10 QSO's and and compared it with my primary info provider. All were correct.
Latest spot below.
Well Log4OM apparently us supplementing incorrect info some how.DF5WW wrote: 02 Feb 2020, 15:48 The cluster is an engine to receive spots. Cluster is not there to correct wrong spots from spotters.
What you see in the main UI are the real informations from the external service u use in fact. If
a spotter have the possibility to spot a grid he can do it and it will be spottet overall the clusters.
Must it be real ? Not really ...
Juergen with Spot Simulator there is no way to ingest a grid locator. Also if you look at the spots from VE7CC there is no grid info.Only as example. I´m a user of a website which providing also spots above 30 MHz. If i send a spot i go
into the side and i have the possibility to send also a locator which is not provided by any external
serviecs
