CAT Frozen on SPLIT for FT-891
HB9VQQ
Re: CAT Frozen on SPLIT for FT-891
Post by HB9VQQ »
Try to add this to your FT-891.ini
Code: Select all
[STATUS5]
Command=(ST;)
ReplyEnd=(;)
Validate=(ST.;)
Flag1=(......1.)|pmSplitOn
Flag2=(......0.)|pmSplitOff
Unfortunately I don't have an FT-891, otherwise I could test myself. This is try and error....
Roland
Flex 6600 - Spiderbeam
HB9VQQ
Post by HB9VQQ »
This is good reference to the Omni-Rig ini file structure http://www.dxatlas.com/omnirig/IniStru.txt
HB9VQQ
Post by HB9VQQ »
One question what is the output if you execute command 'ST; in DX Commander ?
K6KKM
Post by K6KKM »
I made the change suggested to the .ini file and selected that as my rig in OmniRig. No change. Still getting the Split indication with TX in A and RX on B.
Just to confirm, in the FT891 Ini in OmniRig I replaced
[STATUS5]
;not supported
with
[STATUS5]
Command=(ST;)
ReplyEnd=(;)
Validate=(ST.;)
No joy.
I am way beyond my area of expertise, so any help would be appreciated.
HB9VQQ
Post by HB9VQQ »
wo9b
Post by wo9b »
Here is what I came up with, very similar to your solution:
[STATUS5]
Command=(ST;)
ReplyEnd=(;)
Validate=(ST.;)
Flag1=(..0)|pmSplitOff
Flag2=(..1)|pmSplitOn
Flag3=(..2)|pmSplitOn
This works well with the Omnirig client.exe test program.
I am wondering what LOG4OM does with these Omnirig codes? The more I am looking at the CAT structure for the FT891, I am thinking it is a bit limited versus other rigs, including Yaesu rigs. So what does LOG4OM do with the pmSplitOff, pmSplitOn codes? More specifically, how is the Split button on the LOG4OM UI activated? What information is being read from Omnirig to determine the rig's Split status?
wo9b
Post by wo9b »
SOLVED!!!
I corrected the Flag functions in the Status5 section to the following:
[STATUS5]
Command=(ST;)
ReplyEnd=(;)
Validate=(ST.;)
Flag1=(..0.)|pmSplitOff
Flag2=(..1.)|pmSplitOn
Flag3=(..2.)|pmSplitOn
Now the UI in LOG4OM is working perfectly.
Wow, what a colaboration.
Where can I post the revised .ini?
Send it to Alex by email
wo9b
Post by wo9b »
Who is Alex???
wo9b wrote: 05 Feb 2020, 16:52Who is Alex???
That guy that writes Omnirig and all of the other Afreet software
