problem
es2hv
problem
Post by es2hv »
i have log4omV2 2.3.0.0 problems
ES2HV
no grid1.jpg (79.77 KiB) Viewed 5888 times
no flag1.jpg (49.96 KiB) Viewed 5888 times
Re: problem
Please explain the problem
es2hv
Re: problem
Post by es2hv »
the incoming call flag is missing and does not show the grid on the map. Previous version showed log4omv2 2.2.0.0
ES2HV
HB9VQQ
Re: problem
Post by HB9VQQ »
viki wrote: 05 Feb 2020, 07:43 the incoming call flag is missing and does not show the grid on the map. Previous version showed log4omv2 2.2.0.0
ES2HV
Works for me
What are your Info Provider settings ?
Flex 6600 - Spiderbeam
Re: problem
Suggest you check your on line lookup services and update the country file because it's working perfectly with that call sign here
es2hv
Re: problem
Post by es2hv »
settings
HB9VQQ
Re: problem
Post by HB9VQQ »
https://www.qrz.com/page/subscriptions.html
If you don't wanna pay for qrz.com sub then change your primary to HAMQTH
es2hv
Re: problem
Post by es2hv »
Running program - I restarted "run as administrator" and then started to function ... for TNX suggestions ...
ES2HV
HB9VQQ
Re: problem
Post by HB9VQQ »
I am not running Log4OM with administrator privileges and all works fine....
Seems something is strange with your setup.
Re: problem
Looks like you are running QRZ as primary and I do not see you have a subscription on your QRZ.com page.
