IC-7600v2 with Omni-Rig
F5OWK
Post by F5OWK »
Omni-Rig (V 1.19) seems seems not to recognize IC-7600v2.
No problem with HRD and, of course, I've tried to use with Omni-Rig the same port and baud rate than HRD !
Of course alos, the IC-7600 driver was installed before connecting the transceiver.
So, I have no more idea :(
Who can help me ?
Thanks in advance. 73 QRO.
Herve
Re: IC-7600v2 with Omni-Rig
My 7600 worked fine with Omnirig are you sure the baud rate and com port match and is the Icom C-IV address the default Icom one or did you change it?
IK0TIX
Post by IK0TIX »
Herve,
this is my setting for 7610, it's the same of my old 7600:
Max IK0TIX
But are you sure the radio Baud rate is set to 115200 and that the CAT control is set to either USB or ACC according to what you are using.
Did you set CAT to auto start in Program Configuration/CAT?
Are you certain that no other program is using the com port?
It will be a miss-match or menu setting somewhere because I have two friends using the 7610 and neither have issues with Log4OM V2 using Omnirig
I currently have an IC7300 and a 7100 using Omnirig and previously had the 7600 and all work flawlessly.
F1SMV
Post by F1SMV »
Bonjour
test your connexion in first with commander from dx labs software to see more setup. This soft run very well with all trx. After test omnirig.
73 Eric
ps : i have too icom 7600 which run well with omnirig
IK0TIX
Post by IK0TIX »
G4POP wrote: 07 Feb 2020, 00:13 But are you sure the radio Baud rate is set to 115200 and that the CAT control is set to either USB or ACC according to what you are using.
Terry, I have no problems with my 7610. Omnirig and log4om v2 work great for me. Mine was an advice to Eric because for my 7610 (except the baud) I use the same settings that I used for my 7600 ;)
Max IK0TIX
