Unconfirmed filter
Unconfirmed filter
Yesterday I went through QRZ looking for DXCC QSO's that have not give me LOTW confirmation. I just wanted to make sure there was no errors on my end.
I ended up with 34 QSOs that that either:
  • I did not make the log (4)
  • They do not use LOTW (12)
  • Want Money (8)
  • Or have not uploaded to LOTW yet or recently (10)
It was quite a process going to QRZ checking them out, going to LOTW and looking at last login, etc.
Then I was wondering if there is anything Log4OM could do to automate this process. At minimum a filter to give me a report of unconfirmed DXCC QSOs
Any thoughts on how to shortcut this? I felt dirty going to QRZ.COM LOL. But really it was the easiest way I could think of to "see" what was unconfirmed.
I did later figure out I could see the "W" stations just as easy in Log4OM but still was a manual process
Re: Unconfirmed filter
Easy
Filter for LOTW RECEIVED 'not equal to' Yes
Or in QSL manager just check the confirmation received box and select no in drop down
This post should not be in feature request it's a user support issue I will move it
G4POP wrote: 20 Feb 2020, 13:32 Easy
Where can I do that filtering just DX?
I thought this would work but did not.
Try received No as I said in my last post
EDIT.. I am trying this
And also in your last post I thought you were referring to below.
And I expected to find LOTW in here but did not.
No records after applying this.
Which window are you using the filter in
Do you realise the filter does not action until you close the filter window?
Currently trying it in the recent QSO window.
And yes I am closing the window.
Use the QSLmanager Window for this filter ..... It´s not a field to search for in recent QSO tab ....
Still do not know how to filter this to DX only.
And I do not understand References and My References. What is different.
The sort order is hard to follow too.
