In such a configuration as in the pictures, everything works without any problems so far.
QSO login and clearing the callsign window after logging in.
I hope you won't get anything wrong with the program.
When using this configuration do not use ADIF monitor or there is a risk of duplicatessq9jxb wrote: 22 Feb 2020, 09:27 Hello
Janku adif monitor is on because I use fldigi, disable cat in log4om and log in this way qso from fldigi to log4omsq9jxb wrote: 22 Feb 2020, 10:59 Andrzej
ADIF Monitor masz włączony czy wyłączony?
U mnie duplikaty były przy włączonym. W konfiguracji którą mamy nie będzie duplikatów. ADIF Monitor wyłączony.
ADIF Monitor on or off?
I had duplicates on. In the configuration we have there will be no duplicates. ADIF Monitor is off
