LOG40M V2 IS GREAT TOOL FOR HAM .
I HAVE TROUBLE DOWN LOAD FROM LOTW WHEN I SET TO DOWN LOAD FROM 1/2/2020 TO 1/28/2020 IT SAID
USERS NAME/PASSWORD/INCORRECT WHAT AM I DOING WRONG IT UPLOAD GREAT TO LOTW
LOTW DOWN LOAD
Re: LOTW DOWN LOAD
If it was me I would try to go https://lotw.arrl.org/lotw/login and verify your password that you have in Log4OM settings/external Services/LOTW.
When you upload it uses ARRLs TQSL program so don't know if the passwords are handled differently.
But certainly worth a check.
Re: LOTW DOWN LOAD
Claude,KA5MWB wrote: 29 Feb 2020, 02:47 LOG40M V2 IS GREAT TOOL FOR HAM .
Double-triple check your logins and passwords. No special characters are allowed. See Page 79 of the current User Guide.
Also ... make sure the Temporary Path is filled in at: Settings / Program Configuration / External Services / LOTW
Screen clip below is of my configuration.
- V2_lotw-config.JPG (51.15 KiB) Viewed 2906 times
Re: LOTW DOWN LOAD
thanks i got it download great thanks
now i have lost all my data how do i get back?
Re: LOTW DOWN LOAD
Claude,KA5MWB wrote: 29 Feb 2020, 18:50 thanks i got it download great thanks
Need a lot more information than that.
Is/was your database open with your log?
Did you see a listing of your recent QSOs in Tab F7 on the Main UI?
Or are you referring to the LOTW data?
You need to provide more details before we can get to trouble-shooting this problem.
What version of Log4OM are you running? Help / About The 4-digit Version number is just above the Welcome message button.
What version of O/S are you running on your PC? Are there any other programs running or just Log4OM V2?
If you can take any screen clips and upload those with your reply that will also be of very good help.
