QO-100 - No satmode transmitted to eQSL
F4HGU
Post by F4HGU »
Hello All,
I have an issue when uploading my QSO to eQSL.
I think I did the right configuration to log my QSO. It is OK with LOTW but not with eQSL.
My LOG4OM version is: 2.4.0.0
Here is an example on how I log a contact on QO-100:
Then when I go to eQSL website the propagation mode is not detailed and I have to edit manually each contact:
Is there something wrong with my way of logging ? Or a missing parameter in the software to upload correctly to eQSL?
Many thanks for your help !
F4HGU
Re: QO-100 - No satmode transmitted to eQSL
Post by F4HGU »
No comment from any other users ? I double checked my setup and everything looks ok. But I still need to go on eQSL website to edit manually each QSO.
Thx,
Patrice F4HGU
Hi
SX is not supported by eQSL, or i can't find it here:
https://www.eqsl.cc/QSLCard/ADIFContentSpecs.cfm
I'm adding SX to Log4OM list for everyone but i think in that case the issue resides on EQSL side
Hello Patrice,
not longer needed to send a logfile. I have tested at this afternoon and it looks that
we find out something. If not to hard to change it could possibly fixed in next version.
So stay tuned and thank´s for using Log4OM V2 ;)
F4HGU
Post by F4HGU »
Thank you very much for your support !
I like your software and the way it moves forward !
Patrice
Hello Patrice,
some good and some bad news. The first problem was that PROP_MODE = SAT was not exported
to ADIF. This is fixed in the next release. The bad news are that eQSL not accept this PROP_MODE.
They say that they using strictly ADIF 3 but in this case they use the description "Satellite" instead
of the real enumeration SAT.
But not a big deal i think. The lost PROP_MODE will be exported in next release and for the mistake
at eQSL i have opened a support request in the eQSL support forum. Hope they can fix before we
run out the next release ....
