Hi, Terry,
I have a question. Is it possible to save CONFIG settings ???
I want to upgrade to 2.5.0 and I'm afraid I'll have to fill in everything again and reconfigure everything.
Please advise how I can save the configuration I am currently using.
Thank you
Pavel OK1VK
Save CONFIG settings ???
Re: Save CONFIG settings ???
Your config settings are saved automatically with the backup you selected, you have set up a backup of two havnt you?
YES, I SET TO BACK UP TO 2 FOLDERS.
So now I can download version 2.5. Install and enter the same BACKUP path ???
Does the program load the configuration ???
The install will automaticaly load your configuration, the backup is just a safety measure
