I guess this will be a quick fix:
I printed a label for C6AJB.
QSL is via his homecall KG4LJB, which is continetal US, and not Guantanamo Bay as printed on the label.
Guantanamo Bay are only 2x2 calls, e.g. KG4NE.
2x1 and 2x3 are regual stateside.
Label Print: Wrong DXCC for stateside KG4
- 2020-04-26_19h55_21.png (22.05 KiB) Viewed 5587 times
https://www.dk9jc.de
Re: Label Print: Wrong DXCC for stateside KG4
Hello John,
please check this thread too .... viewtopic.php?f=31&t=5318&p=28983&hilit ... bay#p28983
Hi Jürgen,DF5WW wrote: 27 Apr 2020, 04:53 Hello John,
I saw this thread, but is my problem not a different one? When I work Gitmo I know how to change the Country Name.
But here the name of the DXCC comes automaticalls on my label if the manager has a stateside call beginning with "KG4". Not sure how the other topic can help me here.
My gitmo QSOs are correct btw, and the label was OK.
- 2020-04-27_08h50_12.png (8.99 KiB) Viewed 5571 times
Hi John,
yes, it´s different. I only posted the link that you can see that this is a known issue. It shoul´d
not show you a way to fix it by user. There is no way in label print or i don´t find one. But on
known issues Lele is working on.
Also thank´s for reporting this ...
By the way, my english
Hello John,
please download the latest country file (updatetd) via the Settings/Update resources menu
and try again. Shoul´d be fixed then.
I looked very carefully and did not find a way, too.
OK thank youDF5WW wrote: 27 Apr 2020, 09:39 But on known issues Lele is working on.
Also thank´s for reporting this ...![]()
No problem to understand. Job well done.
Ok will check it out now.DF5WW wrote: 27 Apr 2020, 10:31 please download the latest country file (updatetd) via the Settings/Update resources menu
and try again.
It worked now. I can confirm that my problem is fixed. Thank you!DF5WW wrote: 27 Apr 2020, 10:31 please download the latest country file (updatetd) via the Settings/Update resources menu
and try again.
I wonder if it is only fixed for KG4LJB now or all non-Gitmo calls starting with KG4?
- 2020-04-27_13h19_05.png (14.2 KiB) Viewed 5545 times
As i´ve checked out in my tests all 2 letter prefixes are now on Gitmo. Single and/or tripple letter
prefixes are on United States. Check the KG4 calls in the main UI callsign input. Try those with
only 1 or 3 letters after KG4 and try too those from KG4AA to KG4ZZ. In my case all 2 letter px was
show´n as Gitmo and all others as US. So the whole Gitmo problem should be fixed.
Thanks to Lele ....
Thanks to Lele ....
I can confirm --> Update of the "Country File" under Settings fixes the problem.
Very nice job, gentlemen. Thank you.
EDIT: Just saw your PN --> No restart was needed.
Thank you too for reporting and testing ...
