I use FTDX-101D via the back of the radio, I use the output for CW Key and use cable usb cw cable this COM10.
I don't find the settings in WinKeyer always get notification time out.
73 Pat
WinKeyer
Re: WinKeyer
For setting in Winkeyer open the winkeyer window and use Settings (F3) ...
Re: WinKeyer
No!
What HARDWARE WINKEYER are you using
Original K1EL serial or usb Winkeyer
Microham with included Winkeyer
US Interface/Timewave Navigator with included Winkeyer
G4ZLP CW Keyer or ProThree with included Winkeyer
NanoKeyer with included Winkeyer
Picokeyer with included Winkeyer
Or some other manufacturer or self built keyer containing the K1EL keyer chip
Re: WinKeyer
Hello Terry,
I use this one
I use this one
Re: WinKeyer
That is not a Winkeyer and it will not work with the Winkeyer interface in Log4om v1 or v2
Re: WinKeyer
Do you have a solution which I can use via USB for V2 ?
Re: WinKeyer
Patrick,
I've been using the WinKeyer-USB for many years. There are variations of this chip available in kits. The approved source in the UK (Kanga Products) is currently closed due to Covid-19, but you can review some options here.
https://www.kanga-products.co.uk/produc ... -cw-keyer/
