Import adif from Outd Log
- Novice Class
Could I ask anybody for some help? I use app Outd Log for my portables. When I use import adif in Log4OM version 1.40 it works great. But if I try to import in Log4OM version 2.5.0.0 so it isn't work
I add adif from the application. Thanks a lot.
Log after import.txt
- (7.17 KiB) Downloaded 177 times
- OutdLog-OK_KR-077.zip
- (730 Bytes) Downloaded 204 times
73 de Jarda OK1JHR
Re: Import adif from Outd Log
The problem is there is no band data in the ADIF from the other program
We have experienced this before and the next release overcomes this problem
Please wait for the next release which is due very soon and then your ADIF files will import fine
Our apologies for this but it is now rectified
- Novice Class
Thanks a lot Terry. I haven't any problem with old version. I am trying a new version sometimes.
So I will looking forward to a new release. If you want you could use my adif for testing.
73 de Jarda OK1JHR
