Hi again,
Not sure if this is a problem with LofW or how I am using Log4OM - as I've been struggling all day with getting my LotW account set up with ARRL. Once set up, I uploaded my recent QSO's to LotW from Log4OM. That worked fine. I can then log into the LofW website and see that I have a number of QSO's uploaded and a number of QSL's awaiting. I then try to download the QSL's within Log4OM. It connects, then produces the following report:
Begin ADIF generation request
ADIF request accepted
ADIF document downloaded
ADIF document parsed: 0 qso found.
Checking my log, none of the expected qso's have LOFW Rcvd status set to Y and no LOTW Rcvd date set.
Am I missing something here with how I have Log4OM setup, or how I am using it, or should I be talking to the LofW staff?
Thanks much. Love the program and the support.
Doug
QSL's in LofW, but download says 0 QSO's
Re: QSL's in LofW, but download says 0 QSO's
Doug,
I assume that there are some verified QSO's on LOTW, if there are not any verified on LOTW website then you will receive the message that you state.
The log shows the the download completed OK "ADIF request accepted" and "ADIF document downloaded" the document was also parsed so it looks like your Log4OM settings are good.
So please confirm that there are some verified QSO's on LOTW or otherwise? Easy to do on their web site
The only other possibility that comes to mind is that you might have the "Download by date range" box checked in the LOTW download window and the "QSL received since" date set to yesterday or today - In this case unless a QSO has been confirmed in the last few hours the result will be as you describe
- Screenshot 2014-02-25 08.13.52.png (35.76 KiB) Viewed 7538 times
Thanks Terry for your help.
Yes, I confirmed via the LofW website that I had some (4) confirmed QSO's or QSL's awaiting. Here is a screen shot showing the confirmed QSL's on the LofW website.
I did try to download with the Download by Date Range checked, and unchecked. When checked, I had a date of 1/1/2014 set. Same result both times, as I described above. Its a good one!
Thanks!
Doug
Thanks!
Doug
Please post screenshots of.....
Your options/external logs window in Log4om
The Log4om download window where the ADIF document parsed 0 records message is shown
Also what version of Log4om are you using?
Thanks Terry,
Here is my Options, External Logs dialog:
Here is the LOTW Download screen: Version of Log4OM is v 1.16.0.0
Note, I AM able to upload to LofW successfully.
Thank you for such excellent support. I am so impressed with the thoughtful design and execution of this program! Its a joy to use.
Doug
Doug
Please download the ADIF file of matched QSO's directly from the LOTW site and email it to me
Terry, I could not find your email address, on your profile or on QRZ. I have attached the LOTW confirmed QSO download ADIF file to this post. In order to attach, I had to change the suffix of the file to .txt. Hopefully that will work.
Thanks! Doug
Thanks! Doug
lotwreport.txt
- (1.63 KiB) Downloaded 432 times
There is an email icon on the right of this forum post please now export you log as an ADIF and email it to me
I must be blind. There is no email icon to the right of your post. There is a "private Message" icon, but it does not allow the attachment of files. What am I missing?G4POP wrote:There is an email icon on the right of this forum post please now export you log as an ADIF and email it to me
