Grid and distance???
ct1hix
Post by ct1hix »
Good Morning
When importing an adif from a VHF contest (n1mm), the distances in the Log4Om log are 0 "zero". Am I doing something wrong?
73 Gomes CT1HIX
Re: Grid and distance???
Hi Gomes,
can you export a part of the N1MM log (only a max of 10 QSO´s) and attach it here ?
Will try to check with ADIF Master and importing it here for some tests.
ct1hix
Post by ct1hix »
Good morning Juergen
In attch go the file "CT1HIX teste"
Thank you
CT1HIX teste.zip
(931 Bytes) Downloaded 252 times
This is a known issue that has been fixed for next release
ct1hix
Post by ct1hix »
Thank you!
G4AON
Post by G4AON »
G4POP wrote: 01 Jun 2020, 14:10 This is a known issue that has been fixed for next release
Terry
Can you post a list of known issues and what is being worked on for future releases?
One issue for me is the auto lookup of data when entering a QSO. If using QRZ it auto enters “F Bloggs” (or whatever his QRZ entry is), even if using the name of Fred in Net Control, or having previously entered Fred in our last QSO entry. Obviously it would help if everyone had more useable data on their QRZ page, but many do not.
There is a setting showing lookup priority, but it lacks an entry for net control or previous QSO.
73 Dave
