FLDIGI integration issue
ik2egl
Post by ik2egl »
I am trying to integrate log4om with fldigi and I have a "URI error" . I have attached the screenshot of the communitation log
please note that:
a) actually I do not have a rig (i am in a laboratory) and CAT is not enabled
b) as I do not have localhost defined so I substituted the http://locahost with 127.0.0.1 (the connection has been sucesfully established with telnet)
c) the OS is win xp
URI not valid.rar
(46.69 KiB) Downloaded 263 times
73 de Don IK2EGL
Re: FLDIGI integration issue
Localhost "should" be defined because it's in windows default tcp structure.
Try "ping localhost" from command line, you should have 127.0.0.1 answer back
This "could" be the issue, i will try to reproduce that right now
ik2egl
Post by ik2egl »
Daniele
the "ping localhost" works fine and so I have modified back the configuration as proposed
no issue on that
73 de Don IK2EGL
And the problem has been fixed?
ik2egl
Post by ik2egl »
yes
from log4om to fldigi and pstrorator all is fine
from fldidi to log4om I need to do some other test (to enable the QSO the qso logging in fldigi also inlog4om)
I noted that, as the well outlined, the manual instructions should be carefully followed to enable the integration data exchange between the twos.
tnx :)
73 de Don IK2EGL
