On three occasions, Log4OM has lost connection to Omnirig. Running ver 1.41 in parallel shows both radios connected and I can switch rigs in ver 1.41 while 2.7,0,0 is unable to communicate with Omnirig.
Omnirig is ver 1.19, rig 1 is a K3 on RS232 and rig 2 is an IC-9700. Both Log4OM and Omnirig are running at "user level", not "admin" level.
AFAIK, the problem is with ver 2.7.0.0. and not present in ver 2.6.1.0
I have a support request/debug trace file generated when the problem happened. I am currently running 2.6.1.0 to see if the same happens in that version.
73 Dave
Loss of connection to Omnirig in ver 2.7.0.0
Re: Loss of connection to Omnirig in ver 2.7.0.0
Update... Problem also present in 2.6.1.0
Using Windows 10 Pro 64 bit, 2004. Both Omnirig and Log4OM running as "user", not as "admin".
73 Dave
73 Dave
Dave,
Can you please run Omnirig and Log4OM as an administrator.
If your not sure how to do that let me know please
Doing that now, to see if the issue is still present.G4POP wrote: 11 Jun 2020, 07:36 Dave,
73 Dave
I am using both Log4OM and Omnirig as "administrator" and Log4OM lost contact with Omnirig this morning... Both radios turned on when it happened. Log4OM ver 2.7.0.2 and Omnirig 1.19
BTW, needing to run a program as "administrator" is an indication the program is needing to write to a directory that is considered as needing protection by Windows. Can the program not be changed to write where it is allowed, if indeed it is the case that admin access is needed in order to run the program.
73 Dave
73 Dave
Hi Dave, that´s only one side of the medal. Administrative privileges are also use to let Omnirig work togehther with more thanG4AON wrote: 12 Jun 2020, 08:27 BTW, needing to run a program as "administrator" is an indication the program is needing to write to a directory that is considered as needing protection by Windows. Can the program not be changed to write where it is allowed, if indeed it is the case that admin access is needed in order to run the program.
73 Dave
one other software (Multithreading). So if you use Omnirig together with Log4OM and WSJT-X/JTDX (as example) all these
softwares must be run as administrator.
