EQSL Upload Error
ZS1RBT
EQSL Upload Error
Post by ZS1RBT »
I am using Log4OM 2.7.0.0
I am receiving
[EQSL UPLOAD] Error: NO MATCH ON EQSL_USER/EQSL_PSWD FOR DATE 20200627 19:36
I am certain that the user, password and QTH are correct. Possibly something to do with the date format?
Re: EQSL Upload Error
Well here is one that I just uploaded a minute ago without issues so its not a Log4OM error or an EQSL issue
So something is incorrect at your end
Perhaps?
1. Using special characters in the password like !"£$%&@ etc - Use only letters and numbers
2. User name, passwords and nickname are case sensitive, perhaps they have been entered incorrectly
3. Wrong Nickname - Check your nickname on the EQSL website in your profile details
ZS1RBT
Post by ZS1RBT »
Thank you for your reply. I have gone over your recommended settings character by character and cannot see any discrepancies. I still believe it has something to do with the date format.
Annotation 2020-07-04 203031.png (15.83 KiB) Viewed 4389 times
Your date format differs from mine. My system date format is actually yyyy-mm-dd, yet it appears in the above snippet as yyyymmdd while your format is dd/mm/yyyy.
73 James.
ZS1RBT wrote: 04 Jul 2020, 18:36 Hi Terry,
73 James.
James,
I just did a single upload to EQsl and it worked FB similar to Terry's results. Image is below.
The reply from EQsl says: "No Match on EQsl user/eqsl pswd ... "
I'm not sure, but that could be a login / password error message (still) from EQsl. I know you have checked that, but could be worth another review.
As for date/time display in Log4OM V2 ... that is controlled by you and how you have set up your date/time display in the Windows O/S.
Log4OM (V1 or V2) do not set how time/date are displayed. We take what is provided by the Windows O/S.
If you change that, make some Q's and try another upload and see what happens.
on8si
Post by on8si »
I have the same problem.
I even have changed my pasword and stil it gives the same message.
on8si
Post by on8si »
Don't think it's the date problem
Have tried that a few times but no problems with uploads to any service.
By the way, have you both your QTH Nickname setted correct in the Log4OM settings ?
It must match (upper- and lowercase) exactly or upload fails. For your correct QTH
Nickname check your accounts site at eQSL.
on8si
Post by on8si »
I have deleted the account in external services.
Started log4om again, put in the user name, password (new one without chharacters) and QTH nickname again, and still doesn't work.
i have no problems with Clublog.
I've seen on youtube the password can't have special characters, so i changed that. But still it doesn't work.
on8si
Post by on8si »
I have found the problem.
Don't use long passwords. (16 characters)
My password is now 8 characters long and now it workes
ZS1RBT
Post by ZS1RBT »
Wow! Thank you on8si!
I shortened my password from 20 to 12 characters and now it works. I wonder what the maximum length is? Definitely something that should be in the user manual.
Also thanks to DF5WW and KI5IO for your suggestions.
73 James.
