I'm happily running WSJT-X without JTAlert. Polling wsjtx_log.adi is working fine. Takes a while after launching Log4OM until newly imported QSOs show up in the Recent QSO list.
What I noticed when migrating from 2.7 to 2.8: Contact references (WAC, DXCC, WAZ etc.) for imported FT4/FT8 QSOs are no longer filled as they were in 2.7. Guess I messed up with a setting, but cannot find which one.
73, Markus HB9BRJ
polling wsjtx_log.adi
Re: polling wsjtx_log.adi
Hi Markus,
You should not be using adif polling for direct connection please follow the instructions in the latest user guide.
I think you might find the references issue disappears when you interface with WSJT correctly.
Thanks for your reply. Changed WSJT-X logging to UDP following manual pages 165/166 and made an FT4 contact (highlighted in blue). Result stays the same: Contact references are missing since logging with 2.8.0.0, also the ITU/WAZ zones remain empty.
- ContactRefBug.png (59.86 KiB) Viewed 4428 times
MarkusHB9BRJ wrote: 02 Jul 2020, 18:52 Hi Terry,
Try rescanning the references in the Awards status maintenance tab
Markus,
The alpha team have checked this out and its working fine for everyone using WSJT direct by UDP to Log4OM, all refs found..
So something is wrong with your setup, probably a setting either in Log4OM or WSJT, have you got the Import from JT message #12 checked OK?
Yes, everything set according to the manual. However just found this in the Log4OM log file:
2020-07-03 07:52:39.4521 INFO: [AwardsDatabase] : Loading Awards list from database
2020-07-03 07:52:39.4521 ERROR: [AwardsDatabase][LoadAwards] : [EXCEPTION] Index was outside the bounds of the array. System.IndexOutOfRangeException: Index was outside the bounds of the array.
This might be the root cause of my problem.
Update:
After "Settings > Update > Log4OM awards" I did another QSO in WSJT-X.
But contact references are still missing. Here's the log:
2020-07-03 08:10:24.6327 INFO: [#=zcts30FnoLJSYST2nbzYh4qY=] : Begin ADIF QSO import
2020-07-03 08:10:24.7147 INFO: [#=z_VTn57$4uLdvTCbd_2QJzPE=] : {b86bc3bb-6513-4058-a81d-3a8dbeaf32d9} FROM WSJT-X JT Message 12 (ADIF) containing Callsign: EA5DQW Date: 03.07.2020 08:10:00 Band: 20m Mode: FT4
2020-07-03 08:10:24.7297 INFO: [#=zJvnPq3KTeCmAry2KrQ==] : ############### ADD QSO Callsign: EA5DQW Date: 03.07.2020 08:10:00 Band: 20m Mode: FT4
2020-07-03 08:10:24.7567 INFO: [#=zDUl03l2d53g$HxZj9g==] : [QRZCOM] Search start on EA5DQW (originally EA5DQW)
2020-07-03 08:10:25.1077 INFO: * [#=zDUl03l2d53g$HxZj9g==][352 ms] : [QRZCOM] Search completed
2020-07-03 08:10:25.1777 INFO: [#=zJvnPq3KTeCmAry2KrQ==] : QSO Callsign: EA5DQW Date: 03.07.2020 08:10:00 Band: 20m Mode: FT4 Saved
2020-07-03 08:10:25.1867 INFO: [AdifManagement] : Begin export single QSO to ADIF string
2020-07-03 08:10:25.1937 INFO: [AdifManagement] : Export QSO to ADIF file completed
2020-07-03 08:10:59.2283 INFO: [#=zr7pAc21aHCvJ46ix6cx0Fho=] : [DELAYED SEND QSO ASYNC] Aligning QSO process started...
2020-07-03 08:10:59.2513 INFO: [#=zr7pAc21aHCvJ46ix6cx0Fho=] : [DELAYED SEND QSO ASYNC] Aligning QSO process completed
Update:
ITU/CQ zones not saved
Fresh download (portable), unzipped into empty directory, entered all essential config data.
When I log a QSO in WSJT-X, the station's info is shown, including country, ITU and CQ zones. When later editing this QSO, award refs are OK, but ITU and CQ zones are shown as 0. See example below.
Hi Markus
Set trace mode in help menu
Have a couple of JT mode qso 's
Then email me the support request from help menu, include the ADIF file
You have my email address
