discrepancy for K2GT
IU3CYV
Post by IU3CYV »
hello to all,
bungiorno this morning I connected K2GT Jtdx showed me hawaii while log4om USA, I checked the data with qrz.com and actually log4om does not correctly indicate the name.
I edited by hand and corrected the status, however if I try to type it again on a new qso it appears USA again.
what do you do in these cases?
73 de Tiziano IU3CYV :roll:
(old callsign IW7EFC)
Re: discrepancy for K2GT
IU3CYV wrote: 19 Jul 2020, 08:21 hello to all,
OM,
What choices do you have set up in Log4OM V2 for Info Providers?
I just entered K2GT into my installation and it brought up the Hawaii QTH information. I checked via both QRZ and HamQTH (Info Providers) and go the proper data each time.
I'm suspecting there is something amiss with the feed from JTDX to Log4OM V2 that is causing the error.
Disconnect your feed from JTDX and then manually enter K2GT into Log4OM V2 and see if your display is different. You may have to restart V2 to completely cut the link from JTDX to ensure there are no artifacts still being sent via the UDP incoming.
IU3CYV
Post by IU3CYV »
I tryed to insert K2GT on my log4om
the corret country is Hawaii OC-019 and not USA
see below
Please reread Nolan´s information and check your settings in Log4OM
Putting in K2GT gives me Hawaii as the real state/country ... Please
check the settings for INFO Providers.
By the way, would be nice we have a signature with your name. Better
to say "Hello Juergen" or "Hello Lele" instead of "Hello OM" ... ;)
IU3CYV
Post by IU3CYV »
hello Juergen my first info provioder is qrz.com
Can you show me your correct configuration?
see below
Hello Tiziano,
in my case this is working ....
But in my case i have HamQTH as preferred source. If you have QRZ.com as preferred source you need a payed
account. If you not a payed subscriber you will not get full information. That´s the reason that nobody can find
me longer on qrz.com.
Tiziano,
Your not a paid xml subscriber to QRZ (Just a Ham Member) you wont get full look ups unless you pay QRZ, try HamQTH which is free
IU3CYV
Post by IU3CYV »
G4POP wrote: 19 Jul 2020, 15:23 Tiziano,
ok Terry but the internal cty file of log4om it is not updated?
Anyway hamqth work fine!
thank you to all
CTY and Clublog files contain different info
If you want to change update freq of the files you can do it in the program config/scheduler
IU3CYV
Post by IU3CYV »
I was sure that all the dxcc were contained in that file.
and in which log4om file has the information of all the dxcc?
