About Recent QSO's view and columns
EA7KJE
Post by EA7KJE »
Hi all!!
Me and a few friends are using Log4OM from various versions before, but in my case I have a column called RowID that numbering the QSO's, but this does not appear on my friends software... What is the reason?? This is very useful for me, and my friends are asking me...
Anotación 2020-07-27 231646.png (125.35 KiB) Viewed 4805 times
Re: About Recent QSO's view and columns
See the section of the user guide about editing the table/grid layouts for information about adding, removing and changing column positions
EA7KJE
Post by EA7KJE »
Yes, I have see and read the manual before made her my question, but still no viewing where are the RowID column that I could see on my program and my friends couldn't not find to be selected or viewed.
EA7KJE wrote: 28 Jul 2020, 22:07 Yes, I have see and read the manual before made her my question, but still no viewing where are the RowID column that I could see on my program and my friends couldn't not find to be selected or viewed.
What versions are you and your friend using, see help/about
EA7KJE
Post by EA7KJE »
All we are using the last version: 2.8.0.0
Open F7 tab. Point your mouse on a column header like Call or whatever you want, hit right mouse key and select edit layout. Check or uncheck RowID.
K5EY
Post by K5EY »
DF5WW wrote: 29 Jul 2020, 13:44 Open F7 tab. Point your mouse on a column header like Call or whatever you want, hit right mouse key and select edit layout. Check or uncheck RowID.
There is no "RowID" available in my Edit Table/Grid Configuration columns dialog:
Charlie -- K5EY
Denton, Texas USA
Log4OM 2 (ver. 2.14.1.0)
Using JTDX (ver. 2.2.156) and JTAlert (ver. 2.50.1)
Intel Core i7-8700 @3.20 GHz (12GB RAM)
Windows 21H1
Hi Charlie,
you´re right. There´s no "RowID" in the popup. Wrote this when i was at QRL and had no
option to open Log4OM. But this is the normal way to enable/disable the shown headers
in the F7 tab layout.
Have enabled/disabled all but no RowID was show´n in the F7 tab. Must be elswhere on
another setup. Not find out yet where it is.
Back to bed ... Next workday starts in 4 hours ... :lol: :lol:
vk1hx
Post by vk1hx »
Hi all,
I just updated to v2.13 and had to reset all my Recent QSO table layout (every options was selected). One thing I've noticed, which was mentioned in the OM of this thread is the "Row" column (Row ID). When I go to the edit Table Layout to add/remove columns I don't see an option to check/uncheck Row ID.
I personally like the Row ID as a table layout option because if you have an issue with entries in the logbook such as errors uploading to external confirmation sites (LoTW, HRDLog, Clublog etc) it often refers to a row ID. When you don't have it as a selected item it can be time consuming to find the offending row data.
I did a search of the Log4OM V2 user guide, however I was unable to find any reference.
Can someone advise how I select the "Row" (Row ID).
Cheers
Phil - VK1HX
You cannot select it
