rac award showing only aboput 10 of 1300+ contacts
Moderator: OE6CLD
how do I get Log4om v2 reread my log to add the RAC award to all my Canadian contacts.
Dave ve3wej / ve3ie
Re: rac award showing only aboput 10 of 1300+ contacts
As described in the manual:
View/Award status/Maintenance and press Rescan Award References
There are only 13 states in Canada so perhaps you have not worked the other three?ve3wej wrote: 12 Aug 2020, 20:26 how do I get Log4om v2 reread my log to add the RAC award to all my Canadian contacts.
Dont expect every Canadian contact to display in award status only worked countries, states, islands, SOTA peaks etc will be counted
In other words you can work Ontario 1000 times on 80m but that counts as just one state worked on that band
I have worked all thirteen, over the last 30 years, but the old entries have no rac reference for award almost 1400 contacts of canadians, and only 5 or 6 are showing up. can log4om be set to rescan for this award. I really have no plans on rentering each manually
Dave ve3wej / ve3ie
Having selected the award in the View/Award status window, go to the 'Maintenance' Tab and click 'Rescan award references've3wej wrote: 14 Aug 2020, 23:03 I have worked all thirteen, over the last 30 years, but the old entries have no rac reference for award almost 1400 contacts of canadians, and only 5 or 6 are showing up. can log4om be set to rescan for this award. I really have no plans on rentering each manually
As Juergen stated this is all detailed in the user guide and he did already provide you with the answer in this thread
ok, I guess I am not quite telling of this issue, but I will try to find the rescan and see what happens
Dave ve3wej / ve3ie
ok, i rescanned the log, and attached is a snippit of the result
Dave ve3wej / ve3ie
Email me an ADIF file of your logbookve3wej wrote: 16 Aug 2020, 01:41 ok, i rescanned the log, and attached is a snippit of the result
its over 13000 contacts, is that ok for an adi, do you want just the canadian contacts....
is there no mass edit I can do here, to have it rescan
Dave ve3wej / ve3ie
tried this, and I still only have 10 contacts of 1400 or so showingDF5WW wrote: 13 Aug 2020, 04:03 As described in the manual:
and most of them i had to manually set
Dave ve3wej / ve3ie
