Auto upload to HRDLOG.NET work intermittently. Have to force manually.
WB5UDI
Post by WB5UDI »
My upload to Hrdlog.net has been working fine, but recently, it is sporadic. One or two QSO's will upload as they are designed (within a minute or two) but then others will not upload at all and I'm forced to manually upload them.
It's not Hrdlog.net, because as soon as I manually upload them they will immediately appear on the Hrdlog.net site.
I have tried setting the default confirmations at both NO and REQUESTED, but that hasn't helped.
I have deleted the name and user key (to Hrdlog.net) and re-entered and saved, so that's not the issue.
Appreciate your answer to this issue, thanks!
Log4OM is such a great software tool!!!
73's de Stan - WB5UDI
Re: Auto upload to HRDLOG.NET work intermittently. Have to force manually.
Versiòn number please - help/about
WB5UDI
Post by WB5UDI »
Sorry about that.....Log$OM 2 - Version 2.8.0.0.
I have just tested that release and its working fine for me.
Please set log level to trace in the program config (Be aware that this will slow the program down) and next time it misfires send me the log file by EMAIL - DO NOT POST IT TO THIS FORUM
WB5UDI
Post by WB5UDI »
OK, just sent you the log file after TRACE was set...FT8 QSO this morning with KK2M didn't upload, after waiting 30 minutes......Hope this helps you resolve my problem.
Thanks in advance,
Stan WB5UDI
Hello Stan,
if i check your callsign at hrdlog.net and see your logbook it looks like the contact
was logged. Could be possible that there´s something wrong with the response from
hrdlog that Log4OM not get info that the QSL was received by HRDlog. Think the result
is that Log4OM don´t set hrdlog send to Y ...
WB5UDI
Post by WB5UDI »
Juergen,
Thanks, but what you are seeing is AFTER I had to manually force the upload in Log4OM, then Hrdlog.net shows the contact looged......so, the problem remains....but I appreciate you looking into this!
73's de Stan WB5UDI
O.K. you not wrote that you have uploaded manually after this 30 minutes, HI .... Have had a problem like
this in the past but only Log4OM have said No but the QSO´s was stored at hrdlog.net. This looks like another
problem. Hope Terry can help if he has checked your logfile ...
