HrdLog Edit, Modify data Qso after sended ....?
EA6ADO
Post by EA6ADO »
Hi friends,
Im glad to use this nice Log program, its grate. I have a problem , after External Services send my data to HrdLog database, i can´t not see the changes from my Log40M2 log sended thru, if a change any qso data after 10 minutes for example.. Does Log40m2 version 2.9.0.0 had capability to edit or modify data and send to HrdLog after 2 minutes ? Or will be implemented in the next future?.
Thanks for the nice work to all staff.
73´s Toni EA6ADO
Re: HrdLog Edit, Modify data Qso after sended ....?
Yes version 2 has a delayed upload in case of edit or delete
EA6ADO
Post by EA6ADO »
Thanks Terry for answer,
then i understand that is not a problem of Log40m2 uploading the edited data.
It might be the problem in the HrdLog DATABASE page that don´t accept a 2 change of the receibed data from log40m2 ?
73´s Toni EA6ADO
As you will see below upload to HRDLog from Log4OM version 2.9.0.0 is working fine, I just worked the 2E0TRF station and it was auto uploaded
EA6ADO
Post by EA6ADO »
Hi Terry.
Ok , until that moment is working fine for me also. But, if you change for example now the RST on the LOg40M to 5/8 of your last station contact, the change is applied well update also few minutes later for you into HRDlog page.?
73´s Toni EA6ADO
No and I don't think HRDLog will accept duplicate QSO'S with that sort of edit only if the band, freq, mode date or time are changed
EA6ADO
Post by EA6ADO »
Thanks Terry,
Yes HrdLog let to change any field data including RST , of the Qso without duplicating.
I did it since 2012 with an old version of ham radio deluxe v5.11 .
Anyway maybe could be my code that can not run in different pc or logbooks.
Thanks again for user support .
73's Toni EA6ADO
