hi you all
on my log40m my freq will work one time and will not show the same as radio again. what has happing?
thanks
ka5mwb
c.l
freq not workihg
Re: freq not workihg
Informations provided are a little bit too scarse
Can you provide us some more informations, like what is your rig, what software are you using for CAT connection (omnirig or hamlib) and your settings?
Daniele IW3HMH
Daniele IW3HMH
hi
it as been work ok what happingwhat did do ?
my rig ic-756proIII set hamlib rig 756 proIII 0.7.1i357 port 8 com baud 19200 stop bit I civ 6e data none rts check dtr check address locahost port 4532
poling delay100 cat check ok what happing what did do wrong
thanks
ka5mwb
thanks
ka5mwb
Hamlib did not work well for me with my ProIII but Omnirig is 100% OK
Have you installed and tried Omnirig?
hi
yes i have omniring installed can not get to work but work a little sum time on bit hamlib not good
thanks
ka5mwb
c.l.beaver
thanks
ka5mwb
c.l.beaver
What interface do you use between computer and rig - manufacturer names and model please
hi
my inerface is usb ci-v cat ct-17 inface model rpc-117-uf. who made it ?
it work great with my ic 718
thanks
ka5mwb
c.l.beaver
thanks
ka5mwb
c.l.beaver
That is made by Valley Enterprises and has had known issues in the past, However please first try this
Move the CI-V interface to another USB socket on your computer but make sure that you then use the correct port number because it will change when you move the cable to a different USB port.
Set up the ProIII "Other' menu as follows
CI-V baud rate 19200
CI-V Address: 6Eh
CI-V Tranceive: on
CI-V with IC-731: Off
Using Omnirig set it up the same as I have my ProIII set up....
Rig type: IC-756 Pro III
Port: The number of your com port
Baud rate: 19200
Data bits: 8
Parity: None
Stop bits: 1
RTS: Low
DTR: High
Poll Int: 400
Timeout: 4000
Then report the result here please
CI-V Address: 6Eh
CI-V Tranceive: on
Baud rate: 19200
Data bits: 8
Parity: None
Stop bits: 1
RTS: Low
DTR: High
Poll Int: 400
Timeout: 4000
hi
terry it is work ok so far in omnirig i had the rts turn to high.
thanks
ka5mwb
c.l.beaver
thanks
ka5mwb
c.l.beaver
I am pleased its OK and thank you for letting us know that it is working, many people do not
