Before I start making big changes to my configuration and for fear of doing something wrong I would like to launch an SOS... So here I am to ask for your help/opinion
I would like to use FLRIG as a radio controller because it has some features that I find interesting, but there is a problem: FlRig does not work with Omnirig. FLRig just uses Hamlib or connect directly to the radio.
So, to use it, I should use Hamlib, but as I have JTDX and at the same time PSTRotator, I need Omnirig to control the remote antenna switch.
I wondered if it will be possible to use Omnirig for PSTRotator + Log4om + JTDX and simultaneously use FLRIG & FLDIGI using the port that is in VSPE.
I hope I got the idea across, I join a diagram.
A long time ago, I had already mentioned this topic, but I think I was not very clear and then I return to the subject in an attempt to be clearer.
Thanks so much for your help.
