I have an Icom IC-7300 and connect it to Log4OM version 2.11.0.0 with Omnirig version 1.19. Sometimes maybe four or five time a day, the rig will lose connection with Log4OM. I can usually re-establish contact by unplugging and reinserting the USB cable, clicking Connect-CAT-Start CAT then opening the CAT interface and clicking the OK button. That gets a little old if it happens several times a day.
I suspect the problem is with Omnirig and not Log4OM. I have checked the archives for this problem and there were several entries, but no real solutions. I looked at Hamlib, but the 7300 is not listed so that was a dead end. Also, the problem doesn't seem to follow any particular pattern that I can see. If it happened when I transmitted, I would suspect RF in the cable, but that doesn't seem to be the case. Any suggestions?
Thanks,
Ron, KI4TN
Icom IC-7300 and CAT
Re: Icom IC-7300 and CAT
I suspect your usb socket is set to sleep in the power saving settings
Thanks, Terry, that is a reasonable suggestion, but I do not have the box checked to turn off the port to save power. In fact, I don't let the computer itself go into sleep mode throughout the day. I save power by turning it off at night.G4POP wrote: 18 Jan 2021, 16:34 I suspect your usb socket is set to sleep in the power saving settings
Ron
Did you check the properties of the usb com port because there are another set of sleep settings there
I am assuming that you have installed the ICOM USB drivers by silicon labs before you connected the radio to the pc?
Thanks for that; I did find the sleep setting turned on there and have turned it off. We will see if it has any effect.G4POP wrote: 18 Jan 2021, 16:58 Did you check the properties of the usb com port because there are another set of sleep settings there
Yes, I have the correct USB driver by silicon labs.G4POP wrote: 18 Jan 2021, 16:59 I am assuming that you have installed the ICOM USB drivers by silicon labs before you connected the radio to the pc?
Hopefully that other sleep setting you suggested will help.
Ron
