EQSL Error
DJ6SX
EQSL Error
Post by DJ6SX »
I'am Fred, DJ6SX.
Paul, G4YKQ, mailed that my FT4 - QSO's uploaded to EQSL shows only MFSK without any SUB MODE. I have tested it and indeed the QSO's where logged as MFSK , no SUB Mode (from beginning of February).
I think it is a problem from EQSL, but I am not sure. I use LOG4OM 2.11.0.0 since December and in the past all was ok.
Any idea?
Fred, DJ6SX
WSJT - JT-Alert - LOG4OM
Re: EQSL Error
Hello Fred,
please use QSO manager and searcg with the filters for FT4 QSO´s "Mode equals FT4". Select a few of them
and export them as ADIF. Check the ADIF for stored submode or not. If it´s there uploads to eQSL should
be correct.
Check at eQSL Outbox your uploaded FT4 contacts. Mode must be "MFSK (FT4)" if so all is correct at your
side. If only MFSK is stored at the eQSL site and your ADIF export shows the Submode correct something
must be wrong at the eQSL site.
DJ6SX
Re: EQSL Error
Post by DJ6SX »
Hello Jürgen,
thank you for your replay. I will give it a try next time.
73... Fred
