Rig control
G3XOV
Rig control
Post by G3XOV »
Hi All,
I'm using an Ic7200 and Ic7000. When I click on an entry in the cluster window, the radio goes to the frequency ok but when using the 7200 it also changes filter bandwidths. Likewise, when using the 7000, it changes filter bandwidths and also changes mode from cw to cw reverse. Is this a blip in the programme or perhaps a bug in Omni Rig?
73 de Ron
g3xov.
Re: Rig control
Ron,
Try unchecking the "CAT will switch to digital modes" check box in the Log4OM/Options/CAT & Cluster tab and let me know what happens
VA3AG
Re: Rig control
Post by VA3AG »
G4POP wrote:Ron,
Terry:
I am using an Icom IC-7410 and when I uncheck "Cat will switch to digital modes" , if i click on a digital spot the freq. changes and it goes to USB like it should. However if i click on a CW spot it goes to CW-R so there is a problem there. Could be related to Omnirig.
Aldo VA3AG
Re: Rig control
Ron/Aldo
The Omnirig ini file for your rigs have CW-U and CW-L these being used dependent upon the band change chosen
You can edit the ini file in Notepad and save it again as an ini file
The rig descriptor ini files reside in the Afreet/Omnirig/Rigs folder which is in the Windows Program files folder
The filter bandwidths for each mode are probably set in the rig menus, Omnirig is not setting your filter widths as far as I can see
Here is the ini file contents for the 7200 (7000 is almost identical) and as you will see there is nothing related to filter width
; Icom IC-7200 command set
; File created by Uwe Lauer, [email protected]
; Tested (for Faros) by: ulauer
; initialize
[INIT1]
[INIT2]
[INIT3]
; set frequency
[pmFreqA]
;VFO A frequency
;not supported
[pmFreqB]
;VFO B frequency
;not supported
[pmFreq]
;operating frequency
Command=FEFE76E0.05.0000000000.FD
Value=5|5|vfBcdLU|1|0
ReplyLength=17
Validate=FEFE76E0050000000000FD.FEFEE076FBFD
[pmRitOffset]
;RIT offset frequency
;not supported
[pmRit0]
;not supported
[pmPitch]
;CW pitch frequency
Command=FEFE76E0.1409.0000.FD
;300Hz=0 600Hz=128 900Hz=255
Value=6|2|vfBcdLU|0.425|-127.5
ReplyLength=15
Validate=FEFE76E014090000FD.FEFEE076FBFD
; set rit/xit/split/rx/tx
[pmSplitOn]
Command=FEFE76E0.0F01.FD
ReplyLength=13
Validate=FEFE76E00F01FD.FEFEE076FBFD
[pmSplitOff]
Command=FEFE76E0.0F00.FD
ReplyLength=13
Validate=FEFE76E00F00FD.FEFEE076FBFD
[pmVfoA]
;not supported
[pmVfoB]
;not supported
[pmVfoEqual]
Command=FEFE76E0.07A0.FD
ReplyLength=13
Validate=FEFE76E007A0FD.FEFEE076FBFD
[pmVfoSwap]
Command=FEFE76E0.07B0.FD
ReplyLength=13
Validate=FEFE76E007B0FD.FEFEE076FBFD
[pmVfoAA]
Command=FEFE76E0.0700.FD
ReplyLength=13
Validate=FEFE76E00700FD.FEFEE076FBFD
[pmVfoAB]
;not supported
[pmVfoBA]
;not supported
[pmVfoBB]
Command=FEFE76E0.0701.FD
ReplyLength=13
Validate=FEFE76E00701FD.FEFEE076FBFD
[pmRitOn]
ReplyLength=13
[pmRitOff]
ReplyLength=13
[pmXitOn]
;not supported
[pmXitOff]
;not supported
[pmRx]
Command=FEFE76E0.1C00.00.FD
ReplyLength=14
Validate=FEFE76E01C0000FD.FEFEE076FBFD
[pmTx]
Command=FEFE76E0.1C00.01.FD
ReplyLength=14
Validate=FEFE76E01C0001FD.FEFEE076FBFD
; set mode
[pmCW_U]
Command=FEFE76E0.0603.FD
ReplyLength=13
Validate=FEFE76E00603FD.FEFEE076FBFD
[pmCW_L]
Command=FEFE76E0.0607.FD
ReplyLength=13
Validate=FEFE76E00607FD.FEFEE076FBFD
[pmSSB_U]
Command=FEFE76E0.0601.FD
ReplyLength=13
Validate=FEFE76E00601FD.FEFEE076FBFD
[pmSSB_L]
Command=FEFE76E0.0600.FD
ReplyLength=13
Validate=FEFE76E00600FD.FEFEE076FBFD
[pmDIG_U]
Command=FEFE76E0.0608.FD
ReplyLength=13
Validate=FEFE76E00608FD.FEFEE076FBFD
[pmDIG_L]
Command=FEFE76E0.0604.FD
ReplyLength=13
Validate=FEFE76E00604FD.FEFEE076FBFD.
[pmAM]
Command=FEFE76E0.0602.FD
ReplyLength=13
Validate=FEFE76E00602FD.FEFEE076FBFD
[pmFM]
;not supported
; read status
[STATUS1]
Command=FEFE76E0.03.FD
ReplyLength=17
Validate=FEFE76E003FD.FEFEE076.03.0000000000.FD
Value1=11|5|vfBcdLU|1|0|pmFreq
[STATUS2]
Command=FEFE76E0.04.FD
ReplyLength=14
Validate=FEFE76E004FD.FEFEE076.04.0000.FD
;is filter byte appended to the mode byte?
Flag1=000000000000.0000000000.FF.0000|000000000000.0000000000.03.0000|pmCW_U
Flag2=000000000000.0000000000.FF.0000|000000000000.0000000000.07.0000|pmCW_L
Flag3=000000000000.0000000000.FF.0000|000000000000.0000000000.01.0000|pmSSB_U
Flag4=000000000000.0000000000.FF.0000|000000000000.0000000000.00.0000|pmSSB_L
Flag5=000000000000.0000000000.FF.0000|000000000000.0000000000.08.0000|pmDIG_U
Flag6=000000000000.0000000000.FF.0000|000000000000.0000000000.04.0000|pmDIG_L
Flag7=000000000000.0000000000.FF.0000|000000000000.0000000000.02.0000|pmAM
Flag8=000000000000.0000000000.FF.0000|000000000000.0000000000.05.0000|pmFM
[STATUS3]
Command=FEFE76E0.1409.FD
ReplyLength=16
Validate=FEFE76E01409FD.FEFEE0761409.0000.FD
Value1=13|2|vfBcdBU|25|300|pmPitch
[STATUS4]
Command=FEFE76E0.1C00.FD
ReplyLength=15
Validate=FEFE76E01C00FD.FEFEE076.1C00.00.FD
Flag1=00000000000000.00000000.0000.01.00|pmTx
Flag2=00000000000000.00000000.0000.0F.00|00000000000000.00000000.0000.00.00|pmRx
G3XOV
Re: Rig control
Post by G3XOV »
Hi Terry
Thanks for your reply. Had a look at "cat will switch to digi modes" and it's already unchecked. Unfortunately, your second post goes way over this old man's head! I'm no computer whizz kid and I'm afraid it's all gobbledegook to me. Think I'll just live with it but many thanks for your replies.
73 de Ron
g3xov.
Re: Rig control
Ron,
If I sent you a modified rig descriptor ini could you save it to the correct directory?
Alternatively if you have Skype or install Teamviewer I could do it for you
VA3AG
Re: Rig control
Post by VA3AG »
Terry:
Let's see if I have this right, I'll use note pad to open the file. I'll change CW-U and CW-L to just CW in both instances and save it!
It should work! Am I correct Terry?
Aldo VA3AG
Re: Rig control
No Aldo you change the code to change mode the CW_U and CW_L are just titles
VA3AG
Re: Rig control
Post by VA3AG »
G4POP wrote:No Aldo you change the code to change mode the CW_U and CW_L are just titles
Ok I got it Terry, is the code in the manual for the radio or can you send me the lines I have to change?
Thanks in advance
Aldo VA3AG
Re: Rig control
Aldo,
Tomorrow I will modify a file and send it to you
