DXCC Error
Re: DXCC Error
In priority 1 i have set the CTY file and clublog. Could be possible that this setting
override a wrong country from qrz.com. But i´m not shure. You may play a bit with
these settings. Fact is that on qrz a wrong country is setted up by the user himself.
So, not longer time at the moment. We carry our younger brother to the grave today.
He was died at a motorcylce crash 3 weeks ago. Family first.
F6FLU
Re: DXCC Error
Post by F6FLU »
DF5WW wrote: 04 Jun 2021, 11:22 So, not longer time at the moment. We carry our younger brother to the grave today.
Ah sorry Juergen, sincere condolences, of course family first ...
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: DXCC Error
Post by F6FLU »
OE6CLD wrote: 04 Jun 2021, 11:17 Hi Daniel,
I'm a QRZ.com subscriber and I have the same problem. As Terry mentioned, this is a problem with QRZ.com. Marco CU7CL needs to correct this under "Update the basic callsign data" and, under Country, select Azores instead of Portugal.
Claus OE6CLD
OK Claus I understand, thank you very much for your comments...
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: DXCC Error
Post by F6FLU »
Hi
I sent an email to Marco about this Problem
Thanks for your help
Dan - F6FLU
https://F6FLU.org
F6EXV
Re: DXCC Error
Post by F6EXV »
Hi all
The Azores are part of Portugal, in terms of administration, are they not ?
I suppose the zip code will tell the Postal system that this is the Azores.
The guy just did not realize indicating Portugal would have these kinds of consequences.
Thanks + 73
Paul F6EXV
OE6CLD
Re: DXCC Error
Post by OE6CLD »
Hi Paul,
I can see that CU7CL still has Portugal instead of Azores in QRZ.com. So for this guy DXCC, if taken from QRZ, always will be wrong as long as he does not change the country from Portugal to Azores in his settings.
You can always edit/change the country in Log4OM to Azores. As long as you don’t do an automatic update (from QRZ) it will stay correct.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
