Real Time Local
F6FLU
Real Time Local
Post by F6FLU »
is it possible to display the correspondent's local time?
For example, I type a call sign, in the "Main" window (F6) I see the "Sunrise" and the "Sunset" and that's fine,
but I would like to see the correspondent's local time in addition.
If this is not yet possible, would it be possible to consider this new function for a future version?
Thanks and 73
Dan - F6FLU
https://F6FLU.org
Re: Real Time Local
Not possible yet. Log4OM works with UTC only which is calculated by your local time at your PC.
Can't tell you that it is possible in a future version, maybe Lele or Terry can tell you more.
F6FLU
Re: Real Time Local
Post by F6FLU »
Thanks for your answer
but
I do not ask that Log4OM use the local time, I just want Log4OM to display the local time of the correspondent ...
for example :
2021-06-23_16h24_23 copie.jpg (156.92 KiB) Viewed 2068 times
Dan - F6FLU
https://F6FLU.org
Re: Real Time Local
I know what you mean but if we use UTC it's the same for everybody around the world. Means that it was not needed yet. The function you called for is not possible at the moment.
F6EXV
Re: Real Time Local
Post by F6EXV »
Hello all
Dan means the correspondant's local time, the logging would still be in UTC time of course.
Just add the correspondant's local time as an indication, maybe just to know if we have to say good morning, good afternoon, or good evening !
Thanks + 73
Paul F6EXV
F6EXV
Re: Real Time Local
Post by F6EXV »
No reply ?
Thanks + 73
Paul F6EXV
