No data showing below operator name
Re: No data showing below operator name
OK Terry, it has now come good after numerous re-boots and re-installs. Not sure which one finally did the business. Only outstanding problem now is that Log4OM seems to have a very limited set of modes (particularly excluding LSB):
I seem to recall that there is a file containing all the modes, but cannot locate it.- G4POP
Probably due to the selection made hereg3ziy wrote: 24 Jun 2021, 08:53 OK Terry, it has now come good after numerous re-boots and re-installs. Not sure which one finally did the business. Only outstanding problem now is that Log4OM seems to have a very limited set of modes (particularly excluding LSB):
Yes, there are no preferred modes showing, and no obvious way to add them. And now the original problem has returned...
Try Settings/update resources/modes
Cant understand why you alone are having all these issues, are you sure that you dont have a virus?
I have done a scan with Malwarebytes and Windows Defender have scanned the entire system with negative virus reports.
Settings/update resources/modes made no difference.
If your up for an Anydesk session drop me an email
I've sent you an email.
