Hi, I'm Chris, a new user, and new to amateur radio, Log4OM, LOTW etc,.
I'm trying to get the automatic upload to LOTW working and at present at close the program seems to hang, Just left with the close screen indefinitely. Far longer than 2 minutes. Eventually I have to close using the Task Manager. This has never worked for me.
Version: 2.18.0.0
This is the log from the close message:
2021-12-07 17:58:09.7998 INFO: [#=zKkI3_XqFZnZqLNomTThGWnErOpab] : ##################### USER REQUESTED APPLICATION SHUTDOWN #####################
2021-12-07 17:58:09.8843 INFO: [SplashScreen] : Shutting down Log4OM application
2021-12-07 17:58:09.8843 INFO: [#=zOdQB6D8GVJFbZeYZWA==] : Shutting down Log4OM application
2021-12-07 17:58:09.8843 INFO: [SplashScreen] : Saving form status...
2021-12-07 17:58:09.8843 INFO: [SplashScreen] : Uploading LOTW data (120 seconds timeout)
2021-12-07 17:58:09.8843 INFO: [#=zOdQB6D8GVJFbZeYZWA==] : Running LOTW Auto Upload
2021-12-07 17:58:09.8974 INFO: [LOTWManagement] : [LOTW] Searching QSO in Requested status for upload to LOTW...
2021-12-07 17:58:09.9136 INFO: [LOTWManagement] : [LOTW] Found 135 QSO. Uploading...
2021-12-07 17:58:09.9167 INFO: [LOTWManagement] : [LOTW UPLOAD] uploading LOG with 135 QSO
2021-12-07 17:58:09.9167 INFO: [AdifManagement] : Begin export to ADIF file: C:\Users\chris\Documents\Log4OM\LOTW_UPLOAD_20211207175809.adi
2021-12-07 17:58:09.9342 INFO: * [AdifManagement][17 ms] : Export to ADIF file completed: 135 QSO
2021-12-07 17:58:09.9342 INFO: [LOTWManagement] : [LOTW UPLOAD] TQSL Version 2.5.9
2021-12-07 17:58:09.9342 INFO: [LOTWManagement] : [LOTW UPLOAD] No private TQSL Password set
2021-12-07 17:58:09.9503 INFO: [LOTWManagement] : [LOTW UPLOAD] Executing TQSL with upload. Parameters: C:\Program Files (x86)\TrustedQSL\tqsl.exe
2021-12-07 18:32:16.9861 INFO: [#=zJLn9s6Tr4e$IXWb9FisXcUo=] : [UPDATE] LoTW users file update start
2021-12-07 18:32:16.9861 INFO: [#=zPNSS0AZiQaVuM9AfUQSY9PBE0hCj] : [LOTW] begin download from
2021-12-07 18:32:19.8711 INFO: [#=zBTr4GtvJFwOxMOJf5l1MHvU=] : [LOTW] begin load from file C:\Users\chris\AppData\Roaming\Log4OM2\lotw.txt
2021-12-07 18:32:20.2582 INFO: [#=zBTr4GtvJFwOxMOJf5l1MHvU=] : [LOTW] load from file completed
2021-12-07 18:32:20.2582 INFO: * [#=zJLn9s6Tr4e$IXWb9FisXcUo=][3272 ms] : [UPDATE] LoTW users file update end
2021-12-07 18:47:19.0017 INFO: [LOTWManagement] : [LOTW UPLOAD] Message from LOTW:
2021-12-07 18:47:19.0017 INFO: [LOTWManagement] : BDB2526 Finding last valid log LSN: file: 1 offset 18416
BDB1518 Recovery complete at Tue Dec 07 17:58:10 2021
BDB1519 Maximum transaction ID 0 recovery checkpoint [1][18360]
TQSL Version 2.5.9 [2.5.9]
2021-12-07 18:47:19.0017 INFO: [LOTWManagement] : 1 Cancelled by user
The Task manager shows that TQSL.exe is running, I suppose that the upload process causes tqsl.exe to be started in the command line mode.
My best guess is that I've not got some part of the set up correct but I'm not sure what. I've attached the LOTW External Services page.
I'm not sure what should be set, the user and password are set to the ones provided on the callsign certificate message from the LOTW people.
The executable and temporary paths are correct, and the log shows action with these.
Not sure what else I can try, I've misunderstood something somewhere, but what?
Hope you can help,
Chris
BTW I can select the adif file manually in tqsl and update manually.
Upload to LOTW problem
Re: Upload to LOTW problem
Try a manual upload in Log4OM using the QSL manager, see if that works OK
Yes, a manual upload using the QSL manager is fine.
TQSL is version 2.5.9, TrustedQSL library V2.5, Configuration data V11.15
Turn on Trace mode in the help menu
try another auto upload
Then check the logfile again it will display more detailed information
PLEASE PLEASE PLEASE! DO NOT DISPLAY LOGFILE CONTENTS ON THE FORUM BECAUSE SOMETIMES YOUR PRIVATE INFO IS INCLUDED
I've tried with trace enabled and obtained a log with a lot more information.
From what I can see TQSL.exe is started but never returns anything. Log4OM sits waiting and that's it.
Can I post the log somewhere? I don't seem to be able to send PMs.
It this was mine I'd put a timeout in the tqsl.exe management thread so if you don't get a response in a reasonable time you can close down cleanly - or not block the UI thread so the user can close.
Chris
Chris
Make sure that you have the latest TQSL build, library and config installed as per the image below
Set the temporary folder in the External services/LOTW tab to C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\temp and try again
Thanks, tried that. no difference. Log4OM still hangs and needs closing using the Task Manager.
Discovered that the TRACE setting has to be enabled every time but have log data for the close. The last LOTWManagement lines are:
Chris
Don't think there is anything sensitive there, if you need the full log let me know.2021-12-09 15:05:49.4282 INFO: [LOTWManagement] : [LOTW] Found 143 QSO. Uploading...
2021-12-09 15:05:49.4282 INFO: [LOTWManagement] : [LOTW UPLOAD] uploading LOG with 143 QSO
2021-12-09 15:05:49.4452 INFO: [AdifManagement] : Begin export to ADIF file: C:\Users\chris\AppData\Roaming\Log4OM2\temp\LOTW_UPLOAD_20211209150549.adi
2021-12-09 15:05:49.4478 INFO: * [AdifManagement][18 ms] : Export to ADIF file completed: 143 QSO
2021-12-09 15:05:49.4635 DEBUG: [LOTWManagement][UploadLog] : [LOTW UPLOAD] ADIF File created successfully
2021-12-09 15:05:49.4635 INFO: [LOTWManagement] : [LOTW UPLOAD] TQSL Version 2.5.9
2021-12-09 15:05:49.4635 INFO: [LOTWManagement] : [LOTW UPLOAD] No private TQSL Password set
2021-12-09 15:05:49.4635 DEBUG: [LOTWManagement][UploadLog] : -d -u -f update -a all -q -x -l "Cherryfield" "C:\Users\chris\AppData\Roaming\Log4OM2\temp\LOTW_UPLOAD_20211209150549.adi"
2021-12-09 15:05:49.4635 INFO: [LOTWManagement] : [LOTW UPLOAD] Executing TQSL with upload. Parameters: C:\Program Files (x86)\TrustedQSL\tqsl.exe
Chris
I thought I'd try running tqsl with the parameters from the log file in a command prompt:
I'm a retired software developer and this is all terribly familiar, interfacing with external programs is really difficult.
It's a shame that TQSL is so unforthcoming.
Chris
Nothing appeared to happen, tqsl just returned with no action, but running tqsl with no parameters starts its UI.C:\Program Files (x86)\TrustedQSL>tqsl.exe -d -u -f update -a all -q -x -l "Cherryfield" "C:\Users\chris\AppData\Roaming\Log4OM2\temp\LOTW_UPLOAD_20211209150549.adi"
Chris
Its a hard one to track because its not happening to everyone.
Please send a support request to [email protected] making sure that you set to Trace mode then try another auto upload first.
Who is [email protected]? Isn't this the correct place to ask for support?
Anyway I've posted a message to that email address, attaching the log file for today.
Chris
Chris
