QSL Labels: name and routing address not taken from the QSO
s57vv
Post by s57vv »
I've changed the name and the postal address of the correspondent within the QSO to reflect the correct information about the specific station (which are different as they are within QRZ.com). However, the changed name and address did not appear properly to be printed on QSL label.
I would expect, the Label print module takes the full name and address from the QSO (in case of conflict between names/addresses the one from last QSO could be taken or user could be warned to select the proper QSO or simply different QSO's to be sent to different address) and not forced from QRZ.com (which is in many cases wrong).
73 de S56VIX
73 Primož S57VV
Rigs: FT-818ND, FT-65, TH87, W2E
Re: QSL Labels: name and routing address not taken from the QSO
You need to change it in the 'Routing' section of the Label Print routine, after the Print routine has done the auto lookup, then it will work OK.
There used to be a choice to select or disable auto lookup but it seems to have vanished, I will check this out
s57vv
Post by s57vv »
Thank you. There is a small roundcycled Icon jut before the address field.
73 de S57VV (recently changed the callsign)
73 Primož S57VV
s57vv wrote: 27 Jan 2022, 20:03 73 de S57VV (recently changed the callsign)
Primoz,
FYI - I just changed your Forum login to match your new/changed callsign. Your password does not change.
s57vv
Post by s57vv »
Thanks. I was wondering how to change in next step.
73 Primož S57VV
73 Primož S57VV
