RX Field in ver 2.20
NR3E
Post by NR3E »
Since the upgrade to ver 2.20 I have noticed that the RX Freq field does not populate any longer. It will populate now only in the SPLIT mode so I am wondering if this is by design.
Thanks,
Ron, NR3E
Re: RX Field in ver 2.20
NR3E wrote: 18 Feb 2022, 15:05 Since the upgrade to ver 2.20 I have noticed that the RX Freq field does not populate any longer. It will populate now only in the SPLIT mode so I am wondering if this is by design.
Thanks,
Ron, NR3E
Ron,
Has been asked/answered here: https://forum.log4om.com/viewtopic.php?f=32&t=7298
NR3E
Post by NR3E »
Thanks, Nolan, for the information. I had actually searched before I posted and nothing came up so I assumed it was a new issue. Apparently my search term was not clear enough.
73, Ron
HB9ETR
Post by HB9ETR »
....but what this shows is that people want it back. Seeing as it was there for 18 releases prior, can we request its return?
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
dl1clm
Post by dl1clm »
I also prefer to have it back as it was in version 2.18
I have not seen an announcement or a mention in update log of this change.
It was changed in version 2.19 and I have been hoping it would be back version 2.20.
73, Dick
Optibeam OB 9-5
NR3E
Post by NR3E »
Just my thoughts....It seems there are a fair number of users that would would like the RX field populated, including myself. I understand that the ADIF standard considers it redundant so it is not needed. How about a compromise? Populate the field in the user interface, but do not include the data with an ADIF export.
Ron, NR3E
