In which directoey go the SOTA files for the portable version? W0C is not available in the distribution.
Matt/K0MOS
Portable Version: Where do SOTA files go?
Re: Portable Version: Where do SOTA files go?
To answer my own question... the file lives in the CONFIG folder.
Now, what is the file 'SotaAssociations.csv' for? How do I update this one?
Matt/K0MOS
Matt/K0MOS
Matt,
The SOTA association file enables the fast identification of the association from the call entered.
No need for you to edit this. File because we will publish a new file whenever new associations join SOTA
SOTA summit list doesn't provide DXCC (we required that, but SOTA guys said it was not possible) so in order to provide summit related to the current DXCC (without need to parse thousand of unfiltered summits) we created the "sotaassociations.csv" file that relates associations with DXCC
Thanks Terry and Daniele,
so the fact that the file only contains 45 entries compared to the 95 SOTA Associations is as designed?
Matt/K0MOS
Matt/K0MOS
Hi Matt, we made all our efforts in making this file correct, based on the "summitlist" file.
If you see an association missing, please try setting a callsign from that country and see if the summit appears.
Thanks Daniele, I am starting to understand how it works
Matt/K0MOS
Matt/K0MOS
