I have checked the Manual but could not find a way to display only Spots from Lotw users in the cluster window. Is this supported ?
Roland
Cluster Filter - Lotw user
Flex 6600 - Spiderbeam
Re: Cluster Filter - Lotw user
Roland,
You could add such to the Feature Request section.
And, as you noted, that level of filtering is not currently in/enabled with Log4OM.
Lele and/or Terry can also add more granularity about the possible feasibility of that filtering and impact to parsing the cluster feed(s).
