Log4OM working great but.........
2e0apg
Post by 2e0apg »
Hi I have Log4OM working great alongside wsjt-x, Gridtracker, and JTAlert except for 1 thing. I have to go into settings and click "Save and Apply" each time I start but after Gridtracker has started before Gridtracker will start receiving information. Once its going it all works great here are images of my settings if there is something else i have to set any help appreciated
Re: Log4OM working great but.........
Are all programs being 'Run as an administrator' ?
w9mdb
Post by w9mdb »
You don't need to "Forward UDP Messages" to Log4OM -- it doesn't know what to do with them anyways.
Don't know if turning that off will make any difference.
JTAlert already sends call sign and logging records.
w9mdb
Post by w9mdb »
Also why do you have the Secondary UDP Server turned on in WSJT-X? Is something listening on 2233?
2e0apg
Post by 2e0apg »
G4POP wrote: 12 Jun 2022, 10:14 Are all programs being 'Run as an administrator' ?
I Tried running all programs as administrator but exact same scenario happens
2e0apg
Post by 2e0apg »
I think i've resolved it by doing what i should have done in the first place I changed the order I loaded each program in the batch file putting Log4OM last everything working great now :D 73
2e0apg
Post by 2e0apg »
w9mdb wrote: 12 Jun 2022, 12:56 Also why do you have the Secondary UDP Server turned on in WSJT-X? Is something listening on 2233?
was following a tutorial on youtube and just copied all settings i could see
2e0apg wrote: 12 Jun 2022, 15:07
Gary,
Would you pls share the URL for that tutorial to my e-mail address: ki5io-nolan AT outlook.com ???
2e0apg
Post by 2e0apg »
KI5IO wrote: 12 Jun 2022, 15:57
Gary,
Sent
