No Frequency in Keyer Interface
F4BPO
Post by F4BPO »
Hi Lele, Terry,
I am using the Keyer Interface with TCI protocol and the frea is appearing at the top of the window but not in field beloz (Freq and RX freq) so once logged there is no frequency showing.
I presume this is a bug.
73 de F4BPO Greg
F4BPO
Re: No Frequency in Keyer Interface
Post by F4BPO »
After closing and re opening it works now
73 de F4BPO Greg
:lol:
F4BPO
Post by F4BPO »
Actually there is really an issue I am using EESDRv3 0.13.0 alpha, maybe it is why it is not working as I think they upgraded TCI version anyway it is working fine in the main interface where frequency show properly but in the keyer interface window there is no frequency, it is a bit boring to enter manually for both freq (tx and rx) for each qso
73 de F4BPO Greg
I am using EESDR3 o.13.0 build 08072022 and just checked that although the main frequency read out is fine its not filling the input frequencies
Noted and we will fix this
F4BPO
Post by F4BPO »
Thank you
73 de F4BPO Greg
Fixed and being tested by team for next release
F4BPO
Post by F4BPO »
Another issue now.
Using EESDR3 0.13.0 build 02092022
Log4OM does not track most of the time the mode.
If I am in USB and switch on the radio to CW log4OM follows but back to USB on the radio log4OM does not switch back to USB, happens a lot.
This is the next version to be released fixing the above issue.
73 de F4BPO Greg
F4BPO wrote: 14 Sep 2022, 04:00 Terry,
Another issue now.
Checking
F4BPO
Post by F4BPO »
I reverted to last stable version of Log4OM and no issues it is only on the beta.
73 de F4BPO Greg
