QSL Confirmation struggle
Re: QSL Confirmation struggle
PA3BZT wrote: 03 Aug 2022, 09:02 And the struggle keeps going on for me.
No one to explain in simple wordings how to deal with the confirmation settings?
Fred, PA3BZT
Fred,
I sent you a personal e-mail yesterday and have not heard back from you. I used your gmail address.
Fred, PA3BZT
Just imagine your old paper log!
If you had sent a card the QSO was marked card sent = Yes
If you had not sent a card the QSO was NOT marked - Us old stagers use N (NO) for this in Log4OM meaning NO I have not sent a card at this time.
Until you received a card your paper log was not marked for the QSL received - Again us oldies use N (No) for this in Log4OM line No I have not received a card.
When a card was received you checked the box or wrote Yes in the QSL RX column - Thats what OM use in Log4OM
If you apply those rules to LOTW, QRZ etc just the same you have cracked it
The only other QSL Card sent status I use sometimes is 'Ignore' for example for my friends on my daily net, they dont want to be swamped with cards from G4POP, one is enough!
OE6CLD
Post by OE6CLD »
No need to make it more complex than necessary. I upload ALL my contacts, usually on a daily basis, to LoTW, eQSL, QRZ.com, Club Log, and all the other online services before I switch off my computer. Therefore, all is set to ‚Y‘.
As mentioned before, for paper QSL cards, it works the same way like in a paper log. Either you have sent a QSL card (Y) or not. How you handle the ‚not‘ case depends on you. Leave the field empty or set it to no (N) if you have not sent a card and only want to answer incoming card.
I usually set my QSL sent status to requested ‚R‘ and print them once a month (or every second). I use ignore (I) for people who indicate, that they are not using the bureau or where I already send a QSL for this band/mode slot. Additionally, I also use the DARC QSL Card printing Service (mainly for different short time activations like castles, SOTA, … where I want different QSL cards). In this case I set the status to queued (Q), because I will upload an ADIF file to the DARC server, and not print a QSL label myself.
Log4OM is very flexible and can adopt to your use case, not the other way around.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
