cluster drops
LA7QTA
cluster drops
Post by LA7QTA »
Hi all.
After I had to switch over to mobile broadband (60mb), the telnet cluster just
dies after 1,5 to 2 hours.
Is there some settings somewhere ??
I have tried another telnet program in paralell, and it don't drop out.
log4om ver 2.23.0.0 and win 10.
/harald
Re: cluster drops
Checking the logfile in trace mode might provide the answer but I suspect that the mobile router is losing connection or closing due to lack of activity.
Your other cluster software may not have a stay alive system to periodically confirm the server is still connected whereas Log4OM does.
If the Log4OM stay alive message does not receive responses after a predetermined number of attempts to reach the server, it stops trying because it assumes you have lost the internet connection, or the server is down.
Not all cluster software is as sophisticated and just sits and forever waits until it sees incoming data, caused perhaps by the router waking up when you do something else on your PC.
LA7QTA
Re: cluster drops
Post by LA7QTA »
Hi Terry.
This does not make sense to me for now.
The spot screen shows that last update was at 09.28.53 as an example for now.
I was using another pc at that moment so network was ok.
Also the router is the same as when I had copper line but then it worked ok.
Here is a snip from the log:
2022-10-25 09:26:38.6892 INFO: [#=zAgl1Y3g32LbH2Ebwxg==] : Found references on IOTA AS078 Hokkaido SAM SAN
2022-10-25 09:26:47.5622 INFO: [#=zAgl1Y3g32LbH2Ebwxg==] : Found references on ENG 0202
2022-10-25 09:27:13.3609 INFO: [#=zAgl1Y3g32LbH2Ebwxg==] : Found references on RDA LP-18
2022-10-25 09:27:29.0901 INFO: [#=zAgl1Y3g32LbH2Ebwxg==] : Found references on Lighthouse challenge ENG-042
2022-10-25 09:28:48.1438 INFO: [#=zAgl1Y3g32LbH2Ebwxg==] : Found references on L/H ENG 202
2022-10-25 09:28:49.1470 WARN: [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext] : Country not found for callsign D1IY in date 25.10.2022 09:28:49
2022-10-25 09:44:31.3351 INFO: [#=z$N66EVWiT4Wmiq1xwbg4bIM=] : [UPDATE] Refreshing solar data start
2022-10-25 09:44:31.3380 INFO: [#=zC2BfmC3$Ch8ncbs0HkvbsZm6OuzN] : Loading Geomagnetic data series
2022-10-25 09:44:31.3400 INFO: [#=zC2BfmC3$Ch8ncbs0HkvbsZm6OuzN] : GEOMAGNETIC DATA (DGD) downloading from https://services.swpc.noaa.gov/text/dai ... ndices.txt
2022-10-25 09:44:31.6706 INFO: [#=zC2BfmC3$Ch8ncbs0HkvbsZm6OuzN] : GEOMAGNETIC DATA (DGD) load from file completed
2022-10-25 09:44:31.6716 INFO: [#=z81jGgu_XEllIE2cqoYO6jJTT1nLi] : Loading Solar data series
2022-10-25 09:44:31.6726 INFO: [#=z81jGgu_XEllIE2cqoYO6jJTT1nLi] : GEOMAGNETIC DATA (DSD) downloading from https://services.swpc.noaa.gov/text/dai ... ndices.txt
2022-10-25 09:44:31.7650 INFO: [#=z81jGgu_XEllIE2cqoYO6jJTT1nLi] : GEOMAGNETIC DATA (DSD) load from file completed
2022-10-25 09:44:31.7660 INFO: [#=zM0$c8sBFqF8CoQx5U8QFQidjBap8ZtqP5BdMpaI=] : Loading Predicted Solar data
2022-10-25 09:44:31.7670 INFO: [#=zM0$c8sBFqF8CoQx5U8QFQidjBap8ZtqP5BdMpaI=] : GEOMAGNETIC DATA (Predicted) downloading from https://services.swpc.noaa.gov/json/sol ... cycle.json
2022-10-25 09:44:32.4928 INFO: [#=zM0$c8sBFqF8CoQx5U8QFQidjBap8ZtqP5BdMpaI=] : GEOMAGNETIC DATA (Predicted) load from file completed
2022-10-25 09:44:32.4938 INFO: [#=z7XQ26SOGrg6GwbJmGcQs0wTAJQwCeBKoEg==] : Calculating HOURLY VOACAP data: JO59hp with 100,0 watts and 46 sun spots on hour: 9
2022-10-25 09:44:32.4958 INFO: * [#=z$N66EVWiT4Wmiq1xwbg4bIM=][1161 ms] : [UPDATE] Refreshing solar data end
2022-10-25 09:44:32.9816 INFO: [#=z7XQ26SOGrg6GwbJmGcQs0wTAJQwCeBKoEg==] : Hourly VOACAP calculation completed
2022-10-25 10:01:54.7110 INFO: [#=zaTy5YOSEqTBMysd5FQ==] : [QRZCOM] Search start on 9N8 (originally 9N8)
2022-10-25 10:01:54.7120 INFO: * [#=z11mAjeDhloY0HiZNMyAtJvZNzNzu] [UPDATEQSO] : ### END PERFORMING UI TESTS ###m
2022-10-25 10:01:55.3515 INFO: * [#=zaTy5YOSEqTBMysd5FQ==][640 ms] : [QRZCOM] Search start on 9N8 (originally 9N8)
2022-10-25 10:01:55.3535 INFO: [#=z$Y3UbzOE7e7XMPdjzQ==] : [QRZCOM] logon start
2022-10-25 10:01:55.8622 INFO: [#=z$Y3UbzOE7e7XMPdjzQ==] : [QRZCOM] logon completed
What can you see out of this ??
/Harald
LA7QTA
Re: cluster drops
Post by LA7QTA »
Hi Terry
Here is another example:
cluster stop at 11.44.34
2022-10-26 11:44:30.3694 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Executing planned scheduler...
2022-10-26 11:44:30.3694 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2022-10-26 11:44:30.3704 TRACE: [LogWriter][DumpProcess] : ## DUMP ##SearchCallsign Countries 1
2022-10-26 11:44:30.3704 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext #=zfxjWg1d4hMIhyiuu2GpaQsg= 1
2022-10-26 11:44:30.3714 DEBUG: [#=zhkttcmEh59GZYqalmg==][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2022-10-26 11:44:30.3714 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Planned scheduler executed...
2022-10-26 11:44:32.8897 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from LA3QAA
2022-10-26 11:44:32.8897 TRACE: [FwHam][ExtractCallsign] : LA3QAA -> LA3QAA with prefix
2022-10-26 11:44:32.8907 DEBUG: * [Countries][SearchCallsign][4952 ms] : Performing Search Callsign on call LA3QAA on date 26.10.2022 11:44:32
2022-10-26 11:44:32.9056 TRACE: [ProgramStorage][GetFlag] : Flag NOR identified.
2022-10-26 11:44:32.9306 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from G8FXC
2022-10-26 11:44:32.9306 TRACE: [FwHam][ExtractCallsign] : G8FXC -> G8FXC with prefix
2022-10-26 11:44:32.9316 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call G8FXC on date 26.10.2022 11:44:32
2022-10-26 11:44:32.9466 TRACE: [ProgramStorage][GetFlag] : Flag GBE identified.
2022-10-26 11:44:32.9726 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from DL6UBM
2022-10-26 11:44:32.9736 TRACE: [FwHam][ExtractCallsign] : DL6UBM -> DL6UBM with prefix
2022-10-26 11:44:32.9736 DEBUG: * [Countries][SearchCallsign][41 ms] : Performing Search Callsign on call DL6UBM on date 26.10.2022 11:44:32
2022-10-26 11:44:32.9916 TRACE: [ProgramStorage][GetFlag] : Flag DEU identified.
2022-10-26 11:44:33.0206 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from CA3HXY
2022-10-26 11:44:33.0216 TRACE: [FwHam][ExtractCallsign] : CA3HXY -> CA3HXY with prefix
2022-10-26 11:44:33.0216 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call CA3HXY on date 26.10.2022 11:44:33
2022-10-26 11:44:33.0326 TRACE: [ProgramStorage][GetFlag] : Flag CHL identified.
2022-10-26 11:44:33.1016 TRACE: [ChatUsers][Drop] : Chat user dropped: GW4SHF
2022-10-26 11:44:34.1233 TRACE: [ClusterManagement][#=zYBF3E1JCfYGE] : [CLUSTER INBOUND MESSAGE] DX de DL7SI: 28028.0 P29RO up, DL7VEE with Team 1144Z from la3waa.ddns.net:8000
2022-10-26 11:44:34.1722 DEBUG: [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext] : Performing QSO search on callsign P29RO
2022-10-26 11:44:34.1732 DEBUG: * [Countries][SearchCallsign][1151 ms] : Performing Search Callsign on call P29RO on date 26.10.2022 11:44:34
2022-10-26 11:44:34.1882 DEBUG: [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext] : No Clublog CQ ZONE found for P29RO
2022-10-26 11:44:34.1892 DEBUG: [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext] : Searching clublog exceptions
2022-10-26 11:44:34.1912 TRACE: [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext] : No Clublog exceptions found for P29RO
2022-10-26 11:44:34.1922 DEBUG: * [#=zBQA14NUM_z1vYr56DLu8E3Wzj3Oi][MoveNext][19 ms] : QSO search on callsign P29RO completed
2022-10-26 11:44:34.1922 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call P29RO on date 26.10.2022 11:44:34
2022-10-26 11:44:34.2072 TRACE: [ProgramStorage][GetFlag] : Flag PNG identified.
2022-10-26 11:44:34.2082 DEBUG: * [Countries][SearchCallsign][15 ms] : Performing Search Callsign on call DL7SI on date 26.10.2022 11:44:34
2022-10-26 11:44:34.2232 DEBUG: [#=zsRkeScoNmkp8TxmLtg==][MoveNext] : Loading Awards items from database for multiple award codes
2022-10-26 11:44:34.2682 DEBUG: * [#=zsRkeScoNmkp8TxmLtg==][MoveNext][44 ms] : Awards reference list retrieved from database
2022-10-26 11:44:34.2692 TRACE: [#=zZhy$aLJHKvZsJyqbrIJq9yQ=][MoveNext] : Cluster ranking search: DXCC 163 Papua New Guinea -> 131
2022-10-26 11:44:34.2702 TRACE: [#=z7oz414EA3hPOgpDQSg==][MoveNext] : Adding 1 spots to cluster database
2022-10-26 11:44:35.3738 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Executing planned scheduler...
2022-10-26 11:44:35.3738 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2022-10-26 11:44:35.3748 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext #=zfxjWg1d4hMIhyiuu2GpaQsg= 1
2022-10-26 11:44:35.3748 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Planned scheduler executed...
2022-10-26 11:44:37.9648 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from JH1BNC
2022-10-26 11:44:37.9658 TRACE: [FwHam][ExtractCallsign] : JH1BNC -> JH1BNC with prefix
2022-10-26 11:44:37.9658 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call JH1BNC on date 26.10.2022 11:44:37
2022-10-26 11:44:37.9818 TRACE: [ProgramStorage][GetFlag] : Flag JPN identified.
2022-10-26 11:44:37.9838 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from DM2DS
2022-10-26 11:44:37.9848 TRACE: [FwHam][ExtractCallsign] : DM2DS -> DM2DS with prefix
2022-10-26 11:44:37.9858 DEBUG: * [Countries][SearchCallsign][19 ms] : Performing Search Callsign on call DM2DS on date 26.10.2022 11:44:37
2022-10-26 11:44:37.9948 TRACE: [ProgramStorage][GetFlag] : Flag DEU identified.
2022-10-26 11:44:37.9958 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from PD2ARI
2022-10-26 11:44:37.9968 TRACE: [FwHam][ExtractCallsign] : PD2ARI -> PD2ARI with prefix
2022-10-26 11:44:37.9968 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call PD2ARI on date 26.10.2022 11:44:37
2022-10-26 11:44:38.0088 TRACE: [ProgramStorage][GetFlag] : Flag NLD identified.
2022-10-26 11:44:40.3908 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Executing planned scheduler...
2022-10-26 11:44:40.3938 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2022-10-26 11:44:40.3968 TRACE: [LogWriter][DumpProcess] : ## DUMP ##SearchCallsign Countries 1
2022-10-26 11:44:40.3978 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext #=zfxjWg1d4hMIhyiuu2GpaQsg= 1
2022-10-26 11:44:40.3988 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Planned scheduler executed...
2022-10-26 11:44:42.9249 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from IW0BMC
2022-10-26 11:44:42.9268 TRACE: [FwHam][ExtractCallsign] : IW0BMC -> IW0BMC with prefix
2022-10-26 11:44:42.9279 DEBUG: * [Countries][SearchCallsign][4931 ms] : Performing Search Callsign on call IW0BMC on date 26.10.2022 11:44:42
2022-10-26 11:44:42.9568 TRACE: [ProgramStorage][GetFlag] : Flag ITA identified.
2022-10-26 11:44:45.4037 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Executing planned scheduler...
2022-10-26 11:44:45.4047 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2022-10-26 11:44:45.4057 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext #=zfxjWg1d4hMIhyiuu2GpaQsg= 1
2022-10-26 11:44:45.4057 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Planned scheduler executed...
2022-10-26 11:44:47.8965 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from MW0KJN
2022-10-26 11:44:47.8985 TRACE: [FwHam][ExtractCallsign] : MW0KJN -> MW0KJN with prefix
2022-10-26 11:44:47.8995 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call MW0KJN on date 26.10.2022 11:44:47
2022-10-26 11:44:47.9395 TRACE: [ProgramStorage][GetFlag] : Flag GBW identified.
2022-10-26 11:44:47.9425 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from DJ1JE
2022-10-26 11:44:47.9435 TRACE: [FwHam][ExtractCallsign] : DJ1JE -> DJ1JE with prefix
2022-10-26 11:44:47.9445 DEBUG: * [Countries][SearchCallsign][44 ms] : Performing Search Callsign on call DJ1JE on date 26.10.2022 11:44:47
2022-10-26 11:44:47.9635 TRACE: [ProgramStorage][GetFlag] : Flag DEU identified.
2022-10-26 11:44:50.4196 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Executing planned scheduler...
2022-10-26 11:44:50.4205 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2022-10-26 11:44:50.4215 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext #=zfxjWg1d4hMIhyiuu2GpaQsg= 1
2022-10-26 11:44:50.4215 TRACE: [#=z73rR4_Vm07ZEgL6mDQ==][MoveNext] : Planned scheduler executed...
2022-10-26 11:44:53.0045 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from BH6JOX
2022-10-26 11:44:53.0065 TRACE: [FwHam][ExtractCallsign] : BH6JOX -> BH6JOX with prefix
2022-10-26 11:44:53.0075 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call BH6JOX on date 26.10.2022 11:44:53
2022-10-26 11:44:53.0525 TRACE: [ProgramStorage][GetFlag] : Flag CHN identified.
2022-10-26 11:44:53.0545 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from YD3ASV
2022-10-26 11:44:53.0555 TRACE: [FwHam][ExtractCallsign] : YD3ASV -> YD3ASV with prefix
2022-10-26 11:44:53.0555 DEBUG: * [Countries][SearchCallsign][46 ms] : Performing Search Callsign on call YD3ASV on date 26.10.2022 11:44:53
2022-10-26 11:44:53.0765 TRACE: [ProgramStorage][GetFlag] : Flag IDN identified.
2022-10-26 11:44:55.4345 TRACE: [#=z73rR4_Vm07Z
73 Harald
Re: cluster drops
Harald
To the contrary that log shows spots received at the stated time followed by call lookups and award checking
LA7QTA
Re: cluster drops
Post by LA7QTA »
Hi Terry.
Also from that moment no spots is printed on screen, the connected button and the cluster button is staying green.
It stays that way for a long time (10-20) minutes and then the screen goes blank, and those two buttons is not green anymore.
Then I go to the connection for cluster screen, some times I have to send disconnect, for then to reconnect to the server again.
I hope I am explaining this good enough.
If I can help in any way please just say the word.
73 Harald
Re: cluster drops
Do you have the same issue with other cluster severs?
Try Ve7CC and GB7MBC and see if you still have the issue
LA7QTA
Re: cluster drops
Post by LA7QTA »
hi Terry.
Yes, it is the same for whatever cluster I am connecting.
73 Harald
LA7QTA
Re: cluster drops
Post by LA7QTA »
Hi Terry.
A little update from me.
After updating sw to ver 2.24.0.0, cluster stays up for abt. 12 hours but then goes down
in the same way as before.
73 Harald
Re: cluster drops
Harald,
As another test: Open the ve7cc cluster in the CC-User APP. Leave it up/running and see if the cluster holds solid via that CC-User APP.
I use the CC-User APP to modify/set all the filters I want for ve7cc. It is free and totally separate from Log4OM.
Just another method of testing for seeing if the cluster will "hold" in an on-line situation.
