SEND SPOTS
ZL3TRR
SEND SPOTS
Post by ZL3TRR »
Hi My send spot is not working . I have had no problem until the start of this week.
The Green button next to the globe is ok and the cluster and cluster server are green.
When I click on the orange spot button the LOG40M 2V at top of page goes black and the dropdown box does not
appear . Any suggestions as to how to fix ???
thanks John :(
Re: SEND SPOTS
Do you see this dialog?
ZL3TRR
Re: SEND SPOTS
Post by ZL3TRR »
Hi Terry ,
No that does not show up like it use to. any suggestions ? should I reinstall program ?
Re: SEND SPOTS
Might be hidden behind something or on another monitor?
Try a fresh install it might help
ZL3TRR
Re: SEND SPOTS
Post by ZL3TRR »
Have done a clean reinstall and still unable to send spot.
it is very frustrating . Any more suggestions ?
Re: SEND SPOTS
Are you registered with a cluster? this is done via email
and is the cluster that your registered to set as the 'Primary' cluster in the telnet set up?
ZL3TRR
Re: SEND SPOTS
Post by ZL3TRR »
Hi Terry ,
Still having this problem. I do note that in cluster management it says im connected which is greyed out and I have one pri active server but I dont see anything in Known servers. See attachment.
Also is the Export ADIF function been disabled as I dont seem to be able to save a file to .adif
Thank you and appreciate your reply
Merry Christmas and Happy new Year John
Screenshot 2022-12-22 162745.jpg (71.96 KiB) Viewed 1312 times
Re: SEND SPOTS
ZL3TRR wrote: 22 Dec 2022, 03:32 I do note that in cluster management it says I am connected which is greyed out and I have one pri active server but I dont see anything in Known servers. See attachment.
Make sure this box is checked in config and restart Log4OM then you should have a full list. Try another cluster ansd see if you can send spots
This is probably a Widows security issue because its working fine, however where EXACTLY are you trying to save an ADIF file from in Log4OM?
ZL3TRR
Re: SEND SPOTS
Post by ZL3TRR »
Hi Terry ,
Thanks for the quick reply.
Clicking on the show stable cluster box fixed the known servers search . Thank You
Re .adif file I was trying to save from File/Export ADIF. I have always kept a spare copy of the log in ADIF incase my computer crashes.
Re my original question as to Not being able to send spots what do you suggest or do I live with it?
Ver 2.25.0.0
When I have a callsign in the callsign box and info populates in boxes and I press the Orange icon the second screen does not come up??
Thanks John
Re: SEND SPOTS
Have you tried a different cluster server
Have you tried a reinstal
Are you sure that your firewall or anti virus is not blocking Log4om?
Sounds like a local instal issue because these issues are not being reported by other users and it works here, both spotting and ADIF export
