CAT problem with FT-857
SQ4BJA
Post by SQ4BJA »
I have a problem with CAT on Yaesu FT-857. LOG4OM switches VFO A / VFO B continuously after connection. I tried with different versions of hamlib. Always the same. It's puzzling that sometimes it works fine, but most of the time it jumps around the VFO. The radio works properly with other programs that communicate via CAT.
The problem occurs in versions 2.24 and 2.25.
Tom SQ4BJA
Re: CAT problem with FT-857
Use Omnirig, hamlib has issues
SQ4BJA
Post by SQ4BJA »
Thanks, it helps.
