Award status questions
m0eas
Post by m0eas »
I have 3 questions (v2.26.0):
1) Is it possible to only display favourite awards in the award drop down menu on the award status screen ? I am only interested in DXCC and WAS but I have to scroll down the list each time to select them.
2) In the ALL view of the awards, Austria (for example) shows as only W on 17m and 12m. If however I change the filter to Wkd not cfmd, Austria does not appear.
3) Is it possible to add a callsign quick filter in the header that filters recent QSOs. If I want to quickly check if I have contacted someone before, I currently have to populate the main callsign screen then have to open the worked before screen and then click the red cross to cancel.
If there was an independent filter box say to the right of the F11 weather tab or as a operator selection in each field heading , I could query without using the call callsign screen
LOG4OM Question 2.docx
(232.47 KiB) Downloaded 87 times
LOG4OM Question3.docx
(37.06 KiB) Downloaded 90 times
LOG4OM Question 1.docx
(135.3 KiB) Downloaded 94 times
Re: Award status questions
Phil,
I'll answer #1 ... Go to Settings / Configuration / Award Preferences ... then move the awards left to right or right to left as you see fit for display in the dropdown.
Clip of my settings is below
KS4VOL
Post by KS4VOL »
How did you add the awards in the left hand column? I have none of those. I have the ones I see in the right column. But 13_COLONIES to WAZ is not in a list on the Settings/Configuration/Award Preferences. Did you manually add them as the left column you have posted above is not listed on my Award Preferences window.
Phil,
Follow the instructions at the bottom of the Award Preferences panel. Drag and Drop or Double-Click to move the awards from one side to another.
The "Active Award" column is what will then appear in the drop-down field related to Awards.
As for 13_Colonies and Route_66 ... those are awards I created for my own use. They are NOT packaged with Log4OM.
m0eas
Post by m0eas »
Screenshot 2023-03-15 215553.png (149.5 KiB) Viewed 1014 times
Thanks for the screen shot. I do not see DXCC or WAS in my left hand list .
Phil,
Go to: Settings / Update Resources / Log4OM Awards
This may take a bit of time. Once completed the banner will appear just to the left of the Note Field. You can click on that and it will advise that the update has completed.
That should then refresh all the awards provided via Log4OM (remember that 13 Colonies and Route 66 are my personal installations awards).
m0eas
Post by m0eas »
I tried that but no difference. DXCC and WAS still missing.
Even moved all those available across to inactive and they still appear in the drop down list
Screenshot 2023-03-16 172157.png (245.13 KiB) Viewed 986 times
Screenshot 2023-03-16 172225.png (91.76 KiB) Viewed 986 times
Phil,
Something is amiss.
Pls do me a favor and d/l and install V 2.26.0.7 (beta).
See if that will get you past the Award issue. Lele has made changes to the Awards area and may resolve.
We're currently doing testing on a couple releases after .7, but this should help.
m0eas
Post by m0eas »
Bingo, that worked thanks.. Needed to use update resources
Screenshot 2023-03-17 090304.png (154.62 KiB) Viewed 975 times
Screenshot 2023-03-17 090323.png (48.89 KiB) Viewed 975 times
m0eas
Post by m0eas »
That's question1 ticked off, thanks so much.
Do you have any thoughts on questions 2 and 3 ?
