LotW inconsistency
LotW inconsistency
Is this a bug ?
- Unbenannt.JPG (65.82 KiB) Viewed 2732 times
Flex 6600 - Spiderbeam
Re: LotW inconsistency
Both QRZ and LOTW had severe issues over last weekend and the early part of this week, is your issue a recent issue or a long term problem?
Persistent
A41DL - QRZ
A41DL - QRZ
- a41dl.JPG (27.25 KiB) Viewed 2725 times
V26EI
QRZ
QRZ
- V26EI-qrz.JPG (12.94 KiB) Viewed 2725 times
Roland,
I've been trying to come up with a similar call that appears in my cluster feed, but "so far" I've not been able to experience what you've shown.
Now ... maybe it is related to the cluster you are using?
FWIW - I use Lee's ve7cc cluster feed.
Maybe something is amiss there? I'll keep scanning to see if I can find similar.
Yep. I did that and also did a search and v26ei is not in that most current updated d/b.
Maybe v26ei is no longer using lotw even though their QRZ.com Detail page indicates they do ??
Their text on the QRZ.com biography page indicates QSL only via OQRS.
Roland,
Another Alpha member just advised he noted that v25ei has just uploaded Q's to lotw today. Their call sign has not been in the most recent d/b files provided by ARRL and hb9bza.
With their recent (today's) upload their call will then again appear in a new d/b list that will trickle down to the cluster nodes and Log4OM as well.
- lotw-developer.jpg (95.21 KiB) Viewed 2700 times
