It would be very useful and convenient to be able to search for calls worked before also using the suffix.
For now, you can only search by the prefix, while in all other logging programs, you can also search by a couple of letters.
Search by suffix
Re: Search by suffix
But surely it already does?
I have entered G4POP/GD0 as a QSO
When I type GD0 in the call field it displays the /GD0 contact in the WB4 window as well as GD0TEP, see below
Now...try to search TEP for GD0TEP
You refered to suffix which is the trailing /Prefix not call sign body
What is the advantage of searching for the part of a call unassociated with the country identifier/prefix/suffix? you will get hundreds of results even on a moderate sized log of say 10K QSO's
I can see the benefit. I can often remember the suffix of someones call but cant remember what their prefix was. For whatever reason the suffix sticks with me.G4POP wrote: 30 Mar 2023, 11:53 What is the advantage of searching for the part of a call unassociated with the country identifier/prefix/suffix? you will get hundreds of results even on a moderate sized log of say 10K QSO's
Hi
One idea that could help the purpose:
Within "Recent QSO's (F7) you can do it with the filter:
Use Callsign
log.callssign like %the suffix to look for%"
Please see what I have if I do it for "XX" suffix
Use Callsign
73 Manuel Fernando CT1BXX
- VK7XX
- Old Man
Hello Manuel... it looks like you need to be working me nextCT1BXX wrote: 01 Apr 2023, 09:02 Hi
Use Callsign
John
VK7XX
Hello John, Yes it would be great.
I will stay tunned in the bands to copy you.
Have a nice week
Have a nice week
I understand that perhaps it is an unattainable request. Yet I found it very useful on HRD when I listened to the final part of a callsign and could tell if it was already logged or not. This, for example, during satellite activities where the stations are almost always the same and you don't have to waste time during the passage.CT1BXX wrote: 01 Apr 2023, 09:02 Hi
Use Callsign
