When I do an ADIF import, the Cnty is recorded "IA,Mahaska". In other words, it puts the state first then a comma then the County. It is not necessary or wanted to have it formatted that way. Just the county name is needed.
Also, when using Log4OM with FLDigi, is it possible to fill in the data entry fields when the lookup is performed by FLDigi?
Thank you for any help given.
Jacob Kroes (KR0ES)
County (Cnty) Recorded Wrong
Re: County (Cnty) Recorded Wrong
Not much help available for this situation I see.
Jacob,
Patience is a virtue ...
I can only address the county display with this reply.
We follow the ADIF standard of the county display: "state abbreviation then county name" and no it won't be changed.
I'm sure that one of the other support team members will try and answer your question related to FLDigi as they have time and/or experience with that mode.
- adif-counties.JPG (51.6 KiB) Viewed 1242 times
Nolan,
If that's the case with the ADIF format, then why when I import to N3FJP ACL for instance, the state is parsed from the county. The same holds true for importing into Ham Radio Deluxe. I'm not asking to change the ADIF format. But I'm asking that Log4OM can parse the State info out of the County field.
Thanks for your response. Overall, I really like Log4OM.
73 Jacob KR0ES
73 Jacob KR0ES
Jacob,KR0ES wrote: 10 Apr 2023, 18:30 Nolan,
73 Jacob KR0ES
I can't speak for how Scott programs ACL or how the folks at Ham Radio Deluxe processes their data.
Currently (and since Log4OM V1) this is how such has been processed in this APP' environment.
You can suggest such a change in the Feature Request portion of the Forum if you like.
