QSO edit window
f8nhf
Re: QSO edit window
Post by f8nhf »
from the qsl manager it works on all
only the automatic mode does not work
73 Denis F8NHF
Re: QSO edit window
You do realise that only LOTW uploads on program closing, all other like QRZ, EQSL ETC upload at the time the qso is saved!
That's assuming you selected it in the program options?
f8nhf
Re: QSO edit window
Post by f8nhf »
yes the LOTW downloads when the program is closed, all the others like QRZ, EQSL ETC download when the qso is saved! normally
Yes I selected in the program options?
but for QRZ, EQSL ETC qso's they don't download when the QSO is recorded
73 Denis F8NHF
Re: QSO edit window
f8nhf wrote: 06 Apr 2023, 15:34 yes the LOTW downloads when the program is closed, all the others like QRZ, EQSL ETC download when the qso is saved! normally
73 Denis F8NHF
Not download its upload on save qso or program close
Downloading is a manual operation in qsl manager
Re: QSO edit window
Where are these QSOs coming from?
Are they logged in the Main UI or are they coming from FT8 program?
f8nhf
Re: QSO edit window
Post by f8nhf »
yes the QSOs are from JTDX/JTAlert
73 Denis F8NHF
Re: QSO edit window
I cant remember if you said but what happens if you log a call directly in the the main user interface? Not a JT QSO. But just add one to the main interface and log. Does it upload properly?
If it logs without issue then the messages coming from JT modes are because of your incoming connection.
f8nhf
Re: QSO edit window
Post by f8nhf »
I have just entered a QSO manually, all the windows are filled correctly when I validate it and it is logged in the recent QSO window (F7) but the "external Services" are not sent.
They are sent when I close LOG4OM
73 Denis F8NHF
Re: QSO edit window
f8nhf wrote: 07 Apr 2023, 14:49 They are sent when I close LOG4OM
Is that how you have it configured? And what "external services" are you are referring to because they are all treated differently. As an example I upload QRZ automatically. But LOTW I dont even upload on close because I want to do that on my own.
f8nhf
Re: QSO edit window
Post by f8nhf »
they are all in automatic except LOTW which is loaded at closing time
73 Denis F8NHF
